Ironhead A place to talk about Ironheads.
Ethanol fuel in a classic
Old 03-25-2013, 11:34 AM
johnsoda's Avatar
johnsoda
johnsoda is offline
5th Gear
Default Ethanol fuel in a classic
From what i understand ethanol fuel is harder on a classic. I've seen debates on here about it, but none of them mention anything about older bikes.
Should I be putting additives in every time I fill up, and whats best one?
Old 03-25-2013, 12:24 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,519 Likes on 2,862 Posts
i am in the antique Motor bike buzz and we use Marvel Mystery Oil in everything 2 or 3 OZ is all you need for 5 gallons
Old 03-25-2013, 06:22 PM
GRAYSKULL's Avatar
GRAYSKULL
GRAYSKULL is offline
3rd Gear
If you use The "E" gas Put Lucas Ethanol treatment in it or use 100% gas if all possible..
Old 03-25-2013, 07:56 PM
IronMick's Avatar
IronMick
IronMick is offline
I "have heard" that the high octane gases do not contain any ethanol. I use 91, the highest generally available around here, and i do not even think about it.
I have not had any of the problems people talk about. I think that ethanol affecting rubber parts [needle tip, bowl gasket] are what is talked about most.
I don't think there are any effects that will actually harm the engine.
Old 03-25-2013, 08:00 PM
brownfoxx1's Avatar
brownfoxx1
brownfoxx1 is offline
ck your state codes. in missouri there's a law that the gas station doesn't have to have a sticker saying that the pump contains "E" but the 93 octain doesn't.
wonder if other states do the same?
Old 03-25-2013, 10:12 PM
johnsoda's Avatar
johnsoda
johnsoda is offline
5th Gear
The guy that owned the bike before used the lucus ethanol treatment. There are a few places around that sell 91 with E0. I will just make special trips and keep some treatment around just in case. The Marvel Mystery Oil, isnt that good to run every so often even if im not running ethanol fuel?
Old 03-26-2013, 08:27 AM
83XLX's Avatar
83XLX
83XLX is offline
I've been running mostly straight gas in mine since late last year. I found a station near my house that sells ethanol-free gas in all 3 grades, and the premium is 93 octane. I'll swear that my bike runs better - a little more power and better throttle response.
Kthumbs13
12-02-2016 11:50 AM
Route66rider
03-11-2010 02:15 AM
whitepearl
01-29-2009 05:31 PM
Topspin
12-19-2008 08:28 PM
mchaous
07-22-2006 09:03 AM
Quick Reply: Ethanol fuel in a classic
