Ironhead A place to talk about Ironheads.
Clutch Pins
Old 07-16-2013, 08:53 PM
xBigMarkx's Avatar
xBigMarkx
xBigMarkx is offline
Default Clutch Pins
I am working on a 68 ironhead with a dry clutch and the clutch worm gear on the right. I put it together (was apart when I got it) and it seems like one of the pins is missing or jammed. The pin that goes in the clutch pin is there and the adjuster screw is there but I tightened the adjuster all the way down the the clutch never engaged. I tried pushing a wire through the hole and it stopped mid way. Does anyone have an idea? How many pins does it have. Thanks
Old 07-21-2013, 06:40 AM
98Ultra's Avatar
98Ultra
98Ultra is offline
Sorry I cant help with the dry clutch. Never worked on those. Do you have the FSM? (service manual)
Just giving this a bump really.
Old 07-21-2013, 08:37 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
its been a while sine i did one you just dont see them anymore - i believe 4 pins is what is in it the special one is in the clutch hat and 3 others different sizes one is thicker and it belongs in the worm gear for the cable i think - like i said its been a while but if i get a chance i will look we have a tin case sporty engine job in the shop and i will look
Old 07-21-2013, 11:51 AM
yellowstone kelly's Avatar
yellowstone kelly
yellowstone kelly is offline
Here you go....
bigredwing
09-01-2011 11:00 AM
congo_usmc
04-22-2010 02:40 PM
kmealp
04-05-2010 06:02 PM
mrthinkshesfunny
01-18-2010 02:11 AM
wolf1477
Ironhead
01-16-2007 04:23 AM
Quick Reply: Clutch Pins
