72 Ironhead oil pump breather and cam install
Ok I have a 72 ironhead and was reading about this oil pump breather and timing that as well as the installation and lining up of all of the cams. I have a manual but everyone here explains it a lot better than the manual. Just a question that I can't seem to understand. I lined up the hole with the timing mark for the oil breather gear and that's fine. Just that when I do so my pinion gear timing mark is around 1 o'clock. Do I need to take the pinion gear off and move it or drop the oil pump and move that so it lines up with 11 o'clock. Or I can just spin it to when it is at 11 o'clock and install the cams but then the oil pump breather hole is not in the correct spot. I've read all the other forums on this but it just does click in my head I guess thanks!
