Sifton Cams Identification or Other
Hello. Could someone please help me...I have a 1965 XLCH and just removed cams and am having trouble identifying them. Could they be Sifton Barracuda, imposter or something else? I have no clue...Here are the markings on each cam. The heads appear to have some beefed up springs also. Please advise if you need more info...Thanks!
1C Cam has the following markings:
1 C 44.5 4 9 30
2C Cam has the following markings:
2C 53 4 9 39
3C Cam has the following markings:
3C 53 4 9 39
4C Cam has the following markings:
4C 44.5 4 9 30
1 C 44.5 4 9 30
2C 53 4 9 39
3C 53 4 9 39
4C 44.5 4 9 30
Here is some info on Mr. Sifton and his cams ...
http://sdrv.ms/1h8AB2C
http://sdrv.ms/1h8AmEI
http://sdrv.ms/1h8AfZC
for me -- C -- is the barracuda ( 207 ) cam and if it is this is wnat it is if you know how to check it you can confirm what i am giving you
32 56 duration = 268*
X add them plus 180* @.053 lobe lift X rocker ratio = .336 x 1.43 =
57 31 Duration 268*
The total cam lift is .480 total lift at the valve - max spring travel coil bind .510 its set on a 102.25 lobe center
TDC lift < valve to valve info - intake .157 -- exhaust .147 you need .060 between the valves @ over lap - can be checked using sparkplug hole -- not easy tho
its a high RPM cam with very strong bottom end and good transition to a powerfull top end --johnjzjz
57 31 Duration 268*
tom sifton was a simple Man he did not get into big long part number the cams are marked correct for a 207 with the location of the cam 1 2 3 4 - wirth a C following each number i have an old sifton book and no pictures are really in it - the 207 shows up no place on any of the C cams he made = hope that helps - the best cam he ever made was a minis / minis - he also had a plus minis but the minis minis was the hottest cam he ever produced - the fake V Twin copy are garbage
auburn08
Engine Mechanical Topics
08-16-2015 07:30 PM
