Ironhead A place to talk about Ironheads.
Runs 10 seconds then stops
Old 03-30-2014, 10:01 AM
Harbri's Avatar
Harbri
Harbri is offline
Default Runs 10 seconds then stops
I posted a thread about 2 weeks a go and had this problem,i changed my electronic ignition modual and this fixed the problem. I had a dynatek DS6-1 DYNA S HD 70 & later dual fire, i used this for 2000 km one year.
My question is ,is this a good unit or are there better ones.I am thinking of going back to the points system,which i can clean and ajust.I know i will have to change the coil if i do this change.Any info is welcome and thanks to you all for the info i recieve.
Old 03-30-2014, 10:58 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,536 Likes on 2,872 Posts
what we used fo many years before electronic ignition become the norm was the dyna magnetic pickup unit that uses the advancer in the cover and a 5 Ohm coil < has to be 5 Ohms or they burn out quickly < put it in and its done but no control like you want today with the gas we have
ultma ign is what i use in my shop it is adjustable for different compressions and can be used with a Voes and duel fire or single fire 3 Ohm coils < ultma coils are garbage throw it away with the box it comes in -- jz
Old 03-30-2014, 12:24 PM
IronMick's Avatar
IronMick
IronMick is offline
+1 on the Ultima ignitions
-1 on the coil - never had a problem with one myself. Have recommended this unit to many forum members over the past several years and no one has reported a problem with the coil. It is pretty well the most popular electronic ignition among IronHead owners.
http://www.ultimaproducts.com/programmableignition.html
You do not need the programming kit.
Jireh Cycles usually has the best price for the complete kit ...
http://stores.ebay.com/Jireh-Cycles/..._sid=207621396
jcsurf
EVO
04-14-2017 05:49 PM
jim70
Shovelhead
01-21-2017 11:51 PM
shizzomynizzo
Shovelhead
06-29-2014 12:07 AM
Jody1976
07-29-2012 12:12 PM
mjaw
EVO
10-23-2009 03:07 PM
Quick Reply: Runs 10 seconds then stops
