Ironhead A place to talk about Ironheads.
Generator
Old 05-05-2014, 10:00 PM
Harbri's Avatar
Harbri
Harbri is offline
Default Generator
For some time now my generator light is staying on for about 4 miles of riding and then flikkers and goes off,which it would do normally before if you rev it up a bit,right after starting it..IF i ride every day no problem,but if i dont run it for say a week it will take about 4 to 5 miles of riding before it goes off and starts to charge again,if lite is on no charging.Any ideas? Thanks
Old 05-06-2014, 05:39 AM
IronMick's Avatar
IronMick
IronMick is offline
The brushes may be sticking. Here is a thread on inspection and cleaning ...
Ironhead 1977 generator brush inspection (with details and pics)
http://xlforum.net/vbportal/forums/s...d.php?t=589224
That author did this with the gen still installed on the bike. I would not do that; better IMO to work on the bench.
Old 05-06-2014, 10:00 PM
Harbri's Avatar
Harbri
Harbri is offline
Thanks Iron Mick,i cleaned them tonight and looks like the lite goes off with a little revs,i,ll have to let it sit for a few days to see what happens.It was dirty .
Old 05-07-2014, 07:06 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
the magnets are weak - they are not hi quality stuff to begin with - and as you are riding and the currect is increasing the magnets get rejuvenated finally the field goes totally to ground and the light goes off
as it sits the magnets loose the charge and need voltage to bring them back --
Old 05-07-2014, 09:57 AM
IronMick's Avatar
IronMick
IronMick is offline
Originally Posted by johnjzjz
the magnets are weak ..
Hey John, magnets in a generator? Perhaps you are thinking of an alternator
Old 05-07-2014, 05:14 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
The field circuit consists of two coils of wire wound around iron poll shoes. The poll shoes are mounted opposed each other on the inside of the generator housing. One end of the coils connects to the A terminal and the other end connects to the F terminal on the generator. The armature is mounted on bearings and held between the poll shoes. When the generator is first built it needs to be polarized. This is done by flowing current through the field coils. This current makes a magnetic field and magnetizes the poll shoes. One shoe will have its north poll facing the armature; the other poll shoes south poll will face the armature. The polarity of the poll shoes will determine the polarity of the out put voltage at the A terminal. When polarizing it is important the make the A terminal more positive than the F terminal. Flowing current the other direction will make the A terminal have a negative voltage.
Old 05-07-2014, 08:43 PM
IronMick's Avatar
IronMick
IronMick is offline
I get that, but there are no magnets in a generator like there are in an alternator?
Old 05-07-2014, 08:51 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
This current makes a magnetic field and magnetizes the poll shoes -
is it not than a magnet -
we are talking about the windings ( pole shoes ) bolted to the generator housing with big screws
abbysdad2006
General Topics/Tech Tips
11
07-03-2019 11:14 AM
AMF91
06-29-2012 04:16 PM
MidnitEvil
10-09-2009 07:53 PM
SportyPig
07-18-2007 06:25 PM
eriv70
08-28-2006 10:25 PM
Quick Reply: Generator
