Ironhead A place to talk about Ironheads.
1973 xlh
Old 06-03-2014, 04:24 PM
ironbeard73's Avatar
ironbeard73
ironbeard73 is offline
Stage II
Default 1973 xlh
I'm sure this problem has come up several times before, my 73 isn't firing on the rear cylinder. I've changed plugs 3 different times and still no change. has good compression, spark and fuel. I'm running a crane cams hi-4 electronic ignition. with everything I have checked I'm leaning towards a bad coil. any input from the ironhead gurus on what else I could check before buying a new coil?
Old 06-03-2014, 05:19 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
Hi 4 allows the this to be single fire or duel fire if its in the single fire mode AND YOU DID NOT SAY what cylinder---- soooo switch the wires and see if the other cylinder goes out instead - then you know its the ignition not the coil
Old 06-03-2014, 05:27 PM
ironbeard73
Stage II
I did say. it's the rear cylinder. it is firing just real weak.
Old 06-03-2014, 05:35 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
how do you know that - you have a meter on it and read the voltage - your problem could be wires as well
Old 06-03-2014, 05:50 PM
IronMick's Avatar
IronMick
IronMick is offline
The only good test for a bad coil is to replace it with a known good unit. It is useful to always have a spare on hand specifically to test situations like this. So if you do buy a new coil and it does not solve the problem, it is not a waste of $s. A spare coil is like any other tool in the tool box.
For me this also applies to the generator and solenoid. Always spares in the shop.
Another possibility is a bad ignition module [Hi-4]. Do you have the instruction sheet? There is a warning on the last page to never crank the engine with no grounded spark plugs in the wires ...
http://www.cranecams.com/uploads/ins.../90004001b.pdf
Try swapping the spark plug wires, as suggested above. This is something else to have spares for.
Loose wires/connections on the coil?
Puzzell
EVO
23
06-09-2020 05:38 AM
splittie65
EVO
30
04-16-2015 06:21 PM
madaug
02-28-2015 08:01 PM
neverdown
08-08-2012 07:45 PM
jhnmflr
07-05-2005 08:31 AM
Quick Reply: 1973 xlh
