Ironhead A place to talk about Ironheads.
78 ironhead
Old 06-19-2014, 08:31 PM
Wcm71's Avatar
Wcm71
Wcm71 is offline
Default 78 ironhead
Fired up the ironhead yesterday morning for nice ride to work. On the way home I noticed going through the gears every time I got to the top end of the each gears the power would drop out even in fifth the power would drop out when I go half throttle. I have a super B carburetor on it that has been giving me problems I have a rebuild kit on its way to fix it. I checked impression today and it was 110-115 psi the book says it should be at120 psi . At what point should I think about replacing rings? Would love to get some feedback and ideas on what I should do. Thanks guys
Old 06-19-2014, 09:52 PM
31choptop's Avatar
31choptop
31choptop is offline
5 th gear? 110-115 psi is good. wouldnt touch the top end
Old 06-19-2014, 09:58 PM
Wcm71's Avatar
Wcm71
Wcm71 is offline
Damn just read what I wrote fourth sorry about that.
Old 06-20-2014, 06:17 AM
IronMick's Avatar
IronMick
IronMick is offline
The compression test, to get accurate results, must be done with both the engine at full operating temperature [immediately after a long, out of city traffic ride] and with the throttle held wide open. If either if these is omitted then the results will be low.
What happens when the power drops out? does it sputter? fade out? whatever?
What ignition is in the bike? points? electronic? if electronic which brand? If you do not know remove the ignition cover [4" round on the cam cover] and post a pic of what is in there.
Old 06-20-2014, 07:10 AM
Wcm71's Avatar
Wcm71
Wcm71 is offline
It has points and when the power drops out I guess you would say fades.
Old 06-20-2014, 05:19 PM
IronMick's Avatar
IronMick
IronMick is offline
How about the compression test - full op temp? throttle wide open using the grip? both of these? Neither?
Uncle Don
EVO
07-06-2019 04:58 PM
buellxb422
Ironhead
05-01-2016 09:23 PM
OLDFLSTN
10-04-2014 01:24 PM
sifularson
10-16-2007 02:55 AM
HD7585
01-04-2007 07:23 PM
Quick Reply: 78 ironhead
