Ironhead A place to talk about Ironheads.
Will an o ring chain fit?
Old 07-20-2014, 10:50 AM
amfhd's Avatar
amfhd
amfhd is offline
Default Will an o ring chain fit?
I could not find a direct answer in the other threads.I have a 1984 XLX. I am going to put a 22t front sprocket on it. Will a o-ring chain work or will there be clearance problems. Thanks for any help.
Old 07-20-2014, 07:41 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,524 Likes on 2,865 Posts
o ring chains come in different widths - some are wider than others so it depends on what you buy - 22 tooth is not going to be good for motor life as the engine will be up about 700 rpms from stock at speed
Old 07-20-2014, 11:12 PM
IronMick's Avatar
IronMick
IronMick is offline
I have been running o-ring and x-ring chains first on my 1980 and now on my 1978 for almost 10 years. They fit with no trouble.
I suggest a 23 tooth front sprocket. That is what most guys run along with a 51 rear. Yields decent acceleration with lower hiway RPMs.
On my 1980 i had to clearance the inside of the sprocket cover to run the 23 with an o-ring chain. Was tedious to determine exactly where and how much, but it worked out well.
Old 07-22-2014, 09:32 AM
83XLX's Avatar
83XLX
83XLX is online now
They came stock with a 21, so a 22 will lower the rpms at any given speed. I have a 23 on my -83, but I had to grind a bit off the sprocket cover mounting bosses to clear the chain. I don't use o-ring chains, so I don't know if you'd need to do any clearancing with a 22 or not.
Old 07-22-2014, 11:08 PM
amfhd's Avatar
amfhd
amfhd is offline
Thanks for the replies. I intend to run 22-47, give or take a tooth on the rear. I was afraid with a 23 I might have clearance problems. I do like the oring chains, I run them on my offroad bikes and on my shovelhead.
Old 07-23-2014, 07:55 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
brain fade i was not thinking sporty
Nine-n-a-half
04-12-2017 09:46 PM
Rollbar
05-07-2015 04:48 PM
fwb35
10-01-2013 05:54 PM
bucaman
Ironhead
03-06-2009 08:53 AM
flsts
03-24-2007 09:28 PM
Quick Reply: Will an o ring chain fit?
