Trying to identify case - Page 2 - Harley Davidson Forums
Knuckle Head A place to talk about Knuckle Head motors.
P
Thread Tools Search this Thread
Old 02-15-2017, 07:14 AM
Speeding Big Twin Speeding Big Twin is offline
One Of The Regulars
If it's authentic the belly number you found indicates the R-H case is a 1951 model Harley case. The first 1 is a code number and for 1951 it was used for 61ci Panheads and 74ci Panheads. The 51 indicates 1951 model. The remaining four numbers represent sequential machining production (numbers there began at 1000 for production models). The R-H case may have originally been mated with a Harley left case and the two halves would have been machined together as a matching pair at the factory and given the same belly number as each other. What happened to the original Harley left case I do not know. Anything could have happened to it. Anyway it seems you now have a Harley R-H case bolted to an MG left case.
Is there anything stamped on top of the R-H case near the rear engine mounting bolt? I cant see anything there in your photos. If the R-H case was originally used for a 61ci engine then Id expect nothing there but if it was originally used for a 74ci engine Id expect a 7 stamped there.
Re the numbers you found on the heads, I imagine they were on the R-H side near the top and near the recesses for the pushrod tubes? If so, I think 6 77 indicates the heads were cast in June 1977.
Eric
The Following User Says Thank You to Speeding Big Twin For This Useful Post:
renerod1969 (02-15-2017)
P
Thread Thread Starter Forum Replies Last Post
HD mirror set Ultra Limited 2016 Oko Stock Harley Take Offs 3 02-09-2017 12:00 PM
Womens harley davidson button up shirt marcocast Gear and Other Items For Sale 9 02-08-2017 05:54 PM
2014 48 tank & joker machine LED turn signals autobite Sportster Parts 1 02-08-2017 10:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
