Milwaukee 8 speed limited?
Old 12-01-2016, 11:46 PM
Ben-diesel's Avatar
Ben-diesel
Ben-diesel is offline
Default Milwaukee 8 speed limited?
Apparently the 2017 Milwaukee 8 bikes have a speed limiter, limiting the maximum speed at 108 mph.
I got this from a Harley mechanic.
Can anyone confirm this?
Old 12-02-2016, 02:01 AM
gixonek's Avatar
gixonek
gixonek is offline
thundermax should take care of that
Old 12-02-2016, 02:13 AM
MatteGlide15's Avatar
MatteGlide15
MatteGlide15 is offline
Received 1,270 Likes on 600 Posts
Heard the same thing.....
Old 12-02-2016, 06:58 PM
YPD485's Avatar
YPD485
YPD485 is offline
I believe that's because the stock tires aren't speed rated.
Old 12-02-2016, 07:40 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,414 Likes on 1,566 Posts
It is a little slower than that but YES there is a Max speed limiter and there is a Max RPM limiter as well. If you want it gone or changed you will need to use a ECM tuning device to solve it. They may not all handle it so check before you buy.
Old 12-02-2016, 07:42 PM
riknbeth's Avatar
riknbeth
riknbeth is offline
Not sure this is right. I was doing 115mph going home from work about a month a ago. I backed off at 115mph....
smitty901 (12-06-2016)
Old 12-02-2016, 08:26 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 8,505 Likes on 4,415 Posts
just my luck, they just raised the local speed limits to 110 here..darnit
The following 2 users liked this post by mjwebb:
dave the welder (08-29-2018), purpledeuce (12-05-2016)
Old 12-05-2016, 08:48 AM
cruisinmann's Avatar
cruisinmann
cruisinmann is offline
Received 1,807 Likes on 627 Posts
Same with me I had mine over 110 multiple times still pulling I backed off not the engine
Old 12-05-2016, 09:28 AM
riknbeth's Avatar
riknbeth
riknbeth is offline
By the way, the bike was smooth as butter all the way.
L8Braker (01-16-2023)
Old 12-05-2016, 11:08 AM
FLSTFI Dave's Avatar
FLSTFI Dave
FLSTFI Dave is offline
Received 5,936 Likes on 2,344 Posts
All M8 bikes are governed to 107, in each gear it is capable of hitting that speed. Ask the tuners, all dyno pulls shut down at 107.
TTS tuner is capable of removing that, not sure about others.
If a bike shows faster the speedometer is off.
Ask a professional tuner or good Harley mechanic
The following 2 users liked this post by FLSTFI Dave:
cmashark (12-05-2016), MrHd1 (12-05-2016)
Quick Reply: Milwaukee 8 speed limited?
