Milwaukee Eight M8 bolt in cam install step by step w/ dyno
#151
We installed Wood WM8-222 cam in our 2017 CVO Street Glide 114" Milwaukee Eight test bike. We also used the Jackpot M8 2/1/2 head pipe & Hi Roller mufflers, AIM VPC clutch, and tuned it with Dynojet Power Vision. This is a bolt in replacement cam that works with stock valve springs, we used FM adjustable pushrods & Wood lifters.
https://www.facebook.com/FuelMoto/vi...4019457506534/
#152
Keep up the great work Fuel Moto. Can't wait to see what you guys do next!
#154
#155
What happened? Numbers seem same as stock, although it was hot out...
#156
Stock as delivered the M8 have been putting out bout 98 tq and 79 hp
That run was made with generic base map with only a slight bit of tweaking done at the time. Altitude was 2150 ft and it was about 90 degrees with 9 % humidity. We have done some tuning along with the help of Jon and the good folks at Trask and it had improved some. Ride ability is good right now sitting at 103 tq and 103 hp. I feel like there is more in this combo and that some pwr is being left on the table. Fo now I will live with this and let the Tmax do its thing. LLatest Dyno Sheet. The Blue was my final tune with out dyno... It ran well enough to take it to Trask Performance for tuning with a Dyno (in red)
#157
#158
#159
Hi Jamie, I'm in the Tunning stage and looking for a timing map/curve for M8 with 777. Be nice to have something to compare and build off of. Not sure how aggressive you can get with timing on this engine or how it responds. I'm being conservative with the timing map right now... does the WM8-777 require higher advances with steeper curves?
Running 107 with 777 cam, V&H Powerduals, HO mufflers, SE A/C (modified), and a Tmax ECM. Any info would greatly be appreciated.
Thanks.
Thanks.
#160
Stock 107 with 777 cam, V&H Powerduals, HO mufflers, SE A/C (modified), and a Tmax ECM. Any info would greatly be appreciated.
Thanks.
