Octane rating opinions?
Old 02-24-2017, 03:09 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,082 Likes on 3,484 Posts
Originally Posted by Pewter
I make my own 120 Octane gasoline from an oil well at my ranch. I was doing 140 mph on the dragon with lean angles of over 70 degrees when, believe it or not, a Tri Glide came under me on a bend and disappeared into the distance. This thread is the best bed time reading for ages.
120 Octane from drip gas???? Now that's stretching it..... But I do believe the part about the Tri Glide ! LMAO !!
  #302
Old 02-24-2017, 06:04 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 8,543 Likes on 4,431 Posts
I just fart in my gas tank and close the gas cap real quick for a 100 octane methane gas additive
  #303
Old 02-24-2017, 08:25 AM
GARY DYER's Avatar
GARY DYER
GARY DYER is offline
I make my own 120 Octane gasoline from an oil well at my ranch. I was doing 140 mph on the dragon with lean angles of over 70 degrees when, believe it or not, a Tri Glide came under me on a bend and disappeared into the distance. Hang on was I riding the dragon or chasing the dragon? This thread is the best bed time reading for ages.
PS What's the best oil to use in my M8?
Well, I don't believe either story.
Neither a 2 wheeler or a TG can do 70mph in a turn on the Dragon, but a trike can take a turn (not a curve) faster then a 2 wheeler. A stock TG faster on a straight away = no way!!
Best oil? = Any brand name 20/50 motorcycle specific oil (dino or syn) will work just fine. But according to H-D, "ONLY" H-D specific oil or diesel oil is acknowledged.
mjwebb, you do that too!? I thought I was the only one to do that. Unfortunately I was only able to get 91 octane. What do you eat to get 100??
  #304
Old 02-24-2017, 08:37 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
depends on how many intended fuel stops and miles I'm going..for long trips I try to limit my food intake to hard boiled eggs and warm Hamms beer
  #305
Old 02-24-2017, 09:55 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
No I don't. In cold weather the engine take a lot longer to warm up to normal operating speed and the oil is a bit thicker in the beginning so it takes more fuel to go the same distance. When I check my mileage book, all the winter time driving I get is 4 to 5 mpg less then I get in the summertime - - every year it's the same. Cold engine/oil takes a toll on the engine in the winter. It's not ALL due to the blend, but yes that does contribute a little.
I understand the concept of colder air making the engine run better, but like me, it takes a little longer to get up to speed in cold weather.
So you're blaming cold weather causing fewer miles per gallon because the engine has to deal with cold thick oil.
So I should get closer to summer mpg using winter brew than say, someone in South Dakota due to weather being colder on average during a typical winter.
However, since we use multi grade (i.e.:10w-50 or 20w-50) it pours like 10wt.
Not much resistance in 10w oil.
Fact is, I see as much as 5-7 mpg due to the winter swill.
Maybe some Midwest/Eastern riders can share their winter mpg experiences?
As far as cold air making the engine run "better".
I define better as better torque, better hp, better response, and better mileage as measured by multiple sources both from on road as well as lab tests.
The more efficient a given engine runs the better the mileage for the same set of conditions.
An engine running in 65deg/20%hum will produce better mileage than an engine running in Florida @ 85deg/80% hum.
So, the reason you get worse mileage during winter months is, in fact, caused by fuels with less energy than in the summer so you will see similar results every year. Many, many riders report here as well as other forums the same reduction (4-6mpg) in mileage in any area that has summer and winter brews.
ICEs always run best (most efficient/best mpg) with cold, dense air. Warm, thin air, always causes sluggish power by comparison.
Bob
  #306
Old 02-24-2017, 01:10 PM
Yukon42's Avatar
Yukon42
Yukon42 is offline
Baby oil; gotta baby that *****!!!
Pewter (02-24-2017)
  #307
Old 02-24-2017, 04:23 PM
GARY DYER's Avatar
GARY DYER
Bob
Absolutely, you get lower mpg in the winter then the summer.
How do you explain getting worse mileage in the winter back in the 60's/70's before there was winter/summer blends or even 10% ethanol??? Don't forget bearings and wheels don't turn as freely when cold until they warm up. All that adds up to a drag on mpg. It's NOT ONLY the fuel mix.
I remember starting in the winter and the car would move slowly at first until it warmed up and the trans seemed to take forever to shift when it got real cold.
  #308
Old 02-24-2017, 04:34 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
I baby my bike..only the best exterior care too!
  #309
Old 02-26-2017, 10:52 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
I guess referring to what you remember over 40 years ago driving/riding very crudely fueled vehicles with carburetors running much less adulterated AND leaded gasoline is scientific enough for you?
Remember back in the 60's we ran straight weight oils for the most part. 90w-140 in the diff, and nice thick gear oil 80wt in the tranny.
With today's synthetics we no longer need to warm the lube oils before driving a vehicle as you did in the 60's/70's.
There are emmisions regs that stipulate standards for pollution while warming.
The lube oils must not drag down the engine creating more emissions.
Warming a car or truck is no longer stipulated in owners manuals.
Today's lubricant, metal, and machining technology is much different today than back in the "good ole days". For this reason the old school thinking, for example, no longer works for engine breakin procedure due to fuel and timing mapping that is completely unforgivable as compared to a carbed engine where the engine has the ability to pull more or less fuel from a jet.
Always best to breakin a fresh build on a dyno where everything is monitored and can be recalibrated for safe running...then give it to owner to enjoy.
Just the way I see it I guess,
Bob
  #310
Old 02-27-2017, 11:09 AM
GARY DYER's Avatar
GARY DYER
Bob
Absolute perfect timing. Yesterday in the Chicago Sun Times automotive section, Bob Weaver gave this answer to a fuel related question - verbatim. "Follow the manual. Although cleaning the throttle body may marginally increase fuel economy, it is not required maintenance. Cold weather affects fuel economy not only due to longer idling times, but greater accessory loads such as window heaters wipers, headlights and so on. Also, until EVERYTING WARMS UP, THE VARIOUS LUBRICANTS(TRANSMISSION, DIFFERENTIAL, WHEEL BEARINGS AND SO ON) AND UNTIL THEY THIN OUT, THEY CAN CAUSE DRAG."
So it's not just the blend.
Just a side note, Saturday it was in the 20's. When I went for a drive, the car was pretty sluggish for about 3 or 4 blocks. That's first hand experience. Also on Sunday I took the bike for a brunch ride (like I do every Sunday), it was in the 30's, it took at least 5 minutes to get up to normal temps - no way would I blip the throttle during that time like I would if it was summer. I use 10/40 syn oil during the winter.
BTW. what part of the country do you live in?
Quick Reply: Octane rating opinions?
