Blinker lights blink to fast
this will fix your problem with fast blinkers
1) Turn Ignition on
2) Turn on 4 way hazards by pressing the hazard button on the controls. DO NOT press both turn signal switch's at the same time. That is the way the hazard activate on PRE CANBUS bikes.
3) Turn the Ignition off letting hazards run. IF the bike has security they will flash 5 or 6 times and then pause. This is normal. They will go back to flashing normal hazard mode.
4) Let hazards run 1-2 minutes.
5)Turn Ignition back on
6) Turn off hazards
7) Turn Ignition off and then back on
8) Check function of turn signals
1) Turn Ignition on
6) Turn off hazards
1) Turn Ignition on
6) Turn off hazards
1) Turn Ignition on
6) Turn off hazards
