Anyone Replaced Daymaker with Hogworkz
I have a 2017 Ultra Limited. Not happy with the stock Daymaker headlamp. The passing lamps work nice although they could shine farther down the road. Would like to know if anyone has replaced their stock Daymaker headlight with a Hogworkz LED headlight? On paper the Hogworkz should be a much brighter lamp.
Stock Daymaker is 1150 Lumens High Beam
750 Lummens Low Beam
Hogworkz is 3200 Lumens High Beam
2400 Lumens Low Beam
Hogworkz is also available with a halo.
I have raised mine as high at it will go. Three full turns is as far it went. I am going to go to the dealer to have them "flash" the lights so the passing lamps will stay on with the puny *** high beam. My high beam shines a relatively small tight ball in the middle of the road. I am glad that it seems as though most people like their 7" Daymaker. To each his own. After owning a Road Glide this set up on a Ultra is lacking, especially for what they cost.
I had a 14 Street Glide a couple of years ago. I removed the dual halogen that came stock on the bike and installed the Trucklite version LED and was not impressed. Took it off sold it and put the OEM double halogen back in.
I put one from eagle lights in my streetglide, 6k color temp, i believe Harley daymaker is 5k. During the day I run high beam and get flashed by cars because its so bright, I'm good with that because thats means they see me! Both beams stay on when on high. At night this light is crazy bright and the path is very wide into the trees on the side of the road.
