Is "wobble" a thing of the past with the M8?
#31
#32
Not new to me. It is very prevalent in bicycles. I fixed up bicycles for over 40 years. The bicycle does not go fast enough to have wobble but bumps will jar a loose steering head.
I bought them at municipal auctions and fixed them up for donation to churches, Salvation Army, Good Will and others. Kids came from all over to have me fix their bikes. I lived in the south Chicago suburbs and did on average about 150 bikes a year.
My son bought my house when I retired. I warned him people would be knocking on his door. It took 2 years before folks finally learned the "Bike Man" didn't live there anymore.
Where I retired too is small and I fix about 2 bikes a year. I need to start throwing out decades of parts inventory as there is no use for them anymore. So far I through out about 300 lbs of crank arms and chain rings, seats, pedals etc.
#33
#34
I have been as fast as 110-112 in a floor board scraping sweeper with out a wobble on a new '17 Road King. Does better than my '14 Road King which was significantly better than my '13 Road King.
IMHO, the '14 Rushmore models were the first HD's that were actually good motorcycles. The '17's were another big step in the right direction.
#35
#36
That's exactly what I did today only to have the supposed Master Tech tell me that because it's in spec they would have to charge me ...He felt the wobble also..but since it was a low speed wobble that he deemed as not an unsafe condition to Wait till my 1000 mile service..I told him why not just adjust it to the higher side of Spec and be done with it ..he Again told me to wait and if it gets worse to bring it in..can't believe that kinda thinking..just bought the Bike yesterday and the third one that I bought from this dealership..looks like it's time for a sit down with the owner..why should I have to ride another 950 miles with a low speed wobble..I thought about doing it myself but after what I payed for the Bike I feel I shouldn't have to.
#37
#38
Harley "wobble"
The infamous Harley FL "Death Wobble" was in 2008 and earlier bikes, caused by soft bushings and a flexible swingarm. I had it in my 2004 Road King, and it would manifest itself in a high-speed, sweeping turn (i.e. 80 mph in a curve and hard on it). It was quite disconcerting when it happened and would startle inexperienced riders. At the time, there were all sorts of aftermarket brackets that would tie in the engine to the swingarm to add rigidity to the bike. Harley fixed it with the 2009 frames, which is one reason if you ever want to pick up a used FL series, stay with that year or newer.
The 2017 bikes track very nicely, I'm impressed with how my Road Glide handles compared to my older Harleys.
Exactly right, DrCollie. The infamous "Harley wobble" is on the rubber mounted cruisers and occurs at the swing arm isolators or "donuts". Easy to tell if you have this condition by riding about 30 mph or so and wiggling the handlebars. If you have it you'll feel like you have a "hinge" behind the seat down in the frame as the *** end will wiggle. If not just the front wheel will move. Had it bad on my old '91 Electra Glide Sport and used the kit from "Glide Pro" of Santee, Ca to fix it. Rode like it was on a rail after installing the kit including front motor mount, swing arm isolators with bushings.
Other conditions like the loose neck bearings, tire pressure, etc. can cause a "wobble" but that is different from the "Harley Wobble" syndrome.
#39
#40
