Motorcycle Metal Fast? Now Control Yourself...
Big Thanx
Old 06-05-2016, 12:29 PM
SmokeyJoe101's Avatar
SmokeyJoe101
SmokeyJoe101 is offline
Default Big Thanx
Howard,
I know I called you to thank you for the work you did on my front forks. But I also wanted to thank you publicly so to speak.
The work you did and the research and time spent on my forks is greatly appreciated. As you know I was about the throw the baby out with the bath water. The couple of years I spent in frustration going from stock to Progressive monotubes to Ohlins. Ohlins are probably great for most but I was not so please with the ride and always knew it should be better. You took a good product and made it great and for that I thank you.
Today when I took my first test ride with them I knew something was different. I took them through the paces hitting the roads I knew and knew how the old setup responded, All I could keep thinking was this is how it should be. I quickly gained new confidence and began hitting the curves harder. What a fantastic ride all around. When I returned my wife knew immediately by the look on my face that I now have satisfaction.
Thanx again Howard
UPSGUY
06-04-2018 09:15 AM
mavrickFLHR
09-02-2012 08:38 PM
UltraTheo
06-06-2011 03:56 AM
1st 96 ultra
03-18-2011 08:12 PM
utahdyna
10-17-2009 10:14 PM
Quick Reply: Big Thanx
