Motorcycle Metal Fast? Now Control Yourself...
320 Spoke or Hub Mount using OEM Dresser Brembos
Old 01-07-2017, 04:33 PM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
Default 320 Spoke or Hub Mount using OEM Dresser Brembos
Finished up a 320mm rotor(s) using stock OEM Brembo FLT/V-Rod calipers. Brackets (Caliper adapter) are at the anodizers but the SS or Iron rotors are in stock. Requires no modifications and no difference in ABS as the wheel turns the same (Diameter). Just the 320mm diameter makes a huge difference between OEM 300mm. Rotors are fully floating and direct bolt up.
Dguy
04-23-2018 10:23 AM
roussfam
07-31-2016 01:45 PM
sabre0909
Touring Parts
03-03-2014 03:54 PM
blackmopar
05-06-2012 12:16 PM
NCTURBOS
Softail Parts
15
02-18-2010 05:34 PM
Quick Reply: 320 Spoke or Hub Mount using OEM Dresser Brembos
