I have a new in box set of S.E. 203 cams & S.E. air cleaner assembly. Will fit twin cams to 2006 except 06 Dyna. $250.00 for both + shipping. Will separate $175.00 for cams. $100.00 for air cleaner.
The air cleaner & cams came out of a big bore kit# 29775-02B. fits 01-06 EFI softail, 02-06
EFI touring, & 04-05 EFI dynas. I am @ work now. I can get numbers later if you need them.
I believe there are 2 types of 203's. These are the wide Morse type chain. They will fit the models I have listed. Also work with S.E. hybrid cam plate with hydraulic tensioners. I just checked the part#s. Cam kit is 29791-05. Air cleaner kit# is 29440-99c. The instruction sheet says This kit fits all 2000-later Softail, 1999-later Dyna, and Touring Twin Cam 88 model motorcycles (except 1999-2000 EFI Touring and 2006-2007 CVO FLHTCUSE/2) Fits stock, big bore CV, and flatside carburetors (except CV51 super bore.)
I hope this helps. *****Any one intersested @ $200.00 for the set?
Reason: found part#s
