Bunch O' Parts - Wheels, brakes, exhaust and more
Bunch O' Parts - Wheels, brakes, exhaust and more - 50 items total
Paypal ready, local pickup with cash is great too. Can ship MOST pieces, not all.
Pics: https://picasaweb.google.com/D.L.Spang/ScooterStuff - pretty sure everything's there.
02 Sensors – Bosch – 27719-07 – $25 ea, $40/both
Air cleaner ***'y - Forcewinder XR2 - for 99-01 Magnetti EFI – black – never been run – $150
Air Cleaner Cover – 7” diameter – NEW chrome - $20
Air Horn – 3 trumpet + compressor and complete installation – never installed - $30
Axle – Front – off '08 touring - $40
Belt Guard – Lower – 60386-04 - $10
Brake Lever – rear - OEM softail - toe flag cut, drilled for peg - $20
Brake Rotor – Front – 41828-05 - $40
Brake Rotor – Rear – 41825-05 - $40
Coil Cover - custom engraved open / vented style – needs refinish or strip and polish - $10
Exhaust – bagger slip-ons – Rush slash-down 3.5” no baffle – black refinish - $100
Exhaust Baffles – Rush 2” core for 3.5” pipes - $50
Exhaust – above assembly complete - $125
Fender Skirt – OEM touring bikes - $10
Fender Tip Ornaments – older FL bikes – brand new - $20ea or $35 / pair (F/R)
Floorboard inserts – passenger - $10/pr
Fork Slider Covers – 45190-04 – New - $30
Grips – for metric bars – blue anodized – 2 pair $10ea
Handlebar Riser Clamp - Wild1 polished aluminum fits Deuce (should fit others) - new $25
Headlight Cowl TOP trim – 8” billet – for Ness teardrop style ie Indians, etc - $25
Helmet – Vega XT DOT half helmet – XS – New in Box - $30
Horn – HD OEM - $20
Horn – HD OEM - used some scratches - $10
Indian Front Lightbar / Turn Signal Bracket - $100
Indian Turn Signals – need minor polishing – same as HD OEM will fit any touring model - $40
Inspection Cover – softail style - $20
Lifter Blocks – Twin Cam – natural aluminum – 17965-99 / 17967-99 - $40/pr gaskets incl
Light Bar / Signal Bracket – HD OEM stock rear - touring chrome – amber lenses - $75
Motor Mount Isolator – Rear – V-Rod – 16298-05 - new - $25ea
Oil line cover – twin cams - $10
Panhead covers – some rust inside. Outside looks great - $75
Pulley – Harley Thunderstar 40414-04 – brand new in box - $150
Seat – Harley Badlander 2-Up – 97-07 baggers - $150
Shift Linkage – rod only – off '00 touring – polished - $20
Shift Linkage – rod only – 11” length, fluted design, satin black finish - $20
Shift Linkage – Polished Stainless - hex shaped – 17.5” - new in package, $99 price tag - $50
Spot Lamp trim rings – OEM chrome - $20/pr
Taillight / Rear Light Bar - Indian Chief – needs rewire - $75
Taillight lens - HD OEM - red w/ tag window up – for 3157 Bulbs - $20
Throttle Sleeve – 2 cable – new - $5 ea
Timing Cover - Twin Cam – several available - $10ea
Tire - Dunlop / Harley D402F 130/90-16 used – still plenty of miles left - $25
Turn Signal – Vintage Bullet Style
Turn Signal Housings - “Deuce” style – used – good to excellent condition - $30
Turn Signal Lenses – Many Styles - $5/pr some new
Turn Signal pair – sportster stock - w/ choice of amber or red lenses. Need wiring - $20
Turn Signal standoffs – short – set of 4 (2 new, 2 used) - $20/all
Wheel – Harley Thunderstar – pulley holes need reworked - $75
Wheels – DNA Mammoth 52 Spoke – 18r/21f w/ Metzeler 180r/120f – front has minor damage - $750 / all
Wheel Hub / Pulley Spacer – 1.415” - $30
Wheel Spacers – off '08 touring - $40
Windshield brackets - Quick Detach - FLT style Stainless - $75
Horn – HD OEM - $20
https://picasaweb.google.com/lh/phot...eat=directlink
was there, but glad you found somethin.
Only have one. Listed as single. Says "signal" only...sorry man...
I have the deuce style housings...those are bullet style, too. You could make 'em front or rear.
I have standoffs and both amber and red lenses for these.
