S&s in-tank fuel pump 55-5089 for custom fuel injected bikes
Custom in-tank fuel pump for fuel injected Harley-Davidsons and custom bikes. Can be mounted in any tank that has enough room inside to fit, and will allow you to mount a custom or different tank on fuel injected bikes. Retails for $609, I paid $572 a few months ago for this kit. I'll sell it for $400. It is brand new, never used or mounted, and has all parts and instructions. I sold the bike that I was planning to use this on, that is why I'm selling it. It has the proper fuel pressure and flow to feed Harley fuel injected motors, as well as big inch custom fuel injected motors. This is the description from S&S:
S&S Cycle 55-5089 Fuel Pump for Harley-Davidson & Custom Applications. Pump can be mounted in any tank. Hollow mounting bolts secure the pump flange to the bottom of the tank and provide an outlet for wiring and pressurized fuel. In-tank fiber filter prevents contaminants from damaging the pump or clogging fuel injectors. Kit contains pump, in tank filter, inlet hose, mounting hardware and instructions. Pump specifications: 58 psi, 12.0 gal/hr, 5A draw. Made in the USA, SOLD AS KIT
Located in Wichita KS 67204
Easier if you PM me. Can't figure out how on this forum :-)
Anyways, Price..? and is it "plug n play" on a 02 Deuce or will i have to alter something else?
Also wondering what to do with fuel level sender. No room for OEM in custom tank and wouldn't use OEM style anyway. Just need a warning light to go off at low level.
