FS: Ported heads for 95/98"
Used ported Twin Cam heads in great cond. drilled for compression releases. These heads were ported by Jelen Dewey the with his Street-Port head work. $400 plus shipping. http://www.deweyspegs.com/tcporting.html
Heads have been water-vapor blasted to clean & remove all carbon & new viton exhaust valve seals installed. These heads was set-up specifically for the Andrews 37 cam with 9.8:1 cr with flat-top pistons. Will work with other cams as well. These heads will work great on a 95”or 98” build.
Also have cyls bored to 95” that could be taken +.01 over or bored to 98”.
_______________________________________________
Also have stock TC88 heads from an '02 engine for sale. Planned on having these ported someday for a bigger motor, but have since changed directions. $120 plus shipping
All items are black with highlighted fins.
PM with any questions.
