Boom Software Update
I also have the same problem. 50% of the time the WB comes up after having shut the bike off while listening to the usb port. I've set it for my favorite, no help, and I also turned off the WB like suggusted, I don't know what this on / on does, as it stills comes up on startup. If anyone finds a solution for this please post. Hopefully the new download will cure this.
Jonnierock
That hard "Favorite" button, the one below the "Home" button on the left side perimeter of the screen is for one favorite; like the station you usually listen to. It won't have anything to do with what the system defaults to at start up. Go to the "Favorites" screen where there are multiple Favorite presets: Home/Favorites and change the WB selections to something else like FM stations. I bet that will solve your problem.
This just turns weather alerts on or off. BTW - this option is only on systems with CB installed.
good advice circa the favorite button. I haven't tried it yet but will soon while playing my normal favorite 'USB' source.
I think the guys having the WB come on is because their hard favorite is the wb ( just a guess). In my case, the same ( first in my favorites list) FM station comes on each time I turn the radio on even though I use USB most of the time.
Jonnierock
And you will, untill they come up with a fix. I've try every fix mentioned here, and it doesn't make any difference. You can wait till the boom box starts without starting the bike and it will come onto the WB. I've Set the home button. Some times it comes up to the USB port, sometimes to my favorite, but mostly the WB. Untill They fix their download, I believe your going to have problems.
Jonnierock
Jonnierock
