Infotainment -Playing music from phone through Bluetooth?
So, my Samsung phone syncs-up fine when I turn on the the ignition. It will receive and place calls just fine. However, if I then try and play music with the phone I have to perform the following steps: select "setup" on the Infotainment system, select "Bluetooth," select "paired devices," select my specific Samsung phone, select "disconnect music," and finally select "connect music."
I have to do this every single time I want to play music from my phone. And then sometimes I have do it several times. It shouldn't be this difficult!
Two etching isn't right with this issue for sure. Like others I have an iPod that stays plugged in the cubby and my phone connects every time I start the bike. I can switch between the two with no problem right from the joy sticks or the infotainment system. I would make sure the software is up to date and then maybe stop by the dealer and demonstrate the issue to them. Good luck and hope you get it resolved soon.
tkuligowski
Audio Systems
03-20-2022 08:40 PM
sulli
2014-2023 Touring Models
17
06-27-2017 03:43 PM
