2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Grips and Levers
Old 10-31-2014, 02:26 PM
alrosse's Avatar
alrosse
alrosse is offline
Default Grips and Levers
Anyone know of a video showing how to replace your grips and levers on a 2014 street glide.
Old 10-31-2014, 08:09 PM
EdandGrace's Avatar
EdandGrace
EdandGrace is offline
Not sure about the levers but search on you tube for grips. Know there is one for a 13 SG. Pretty much the same. Changed the grips on my 13 and 15. On the 15 for the right make sure you loosen the brake fasteners a good bit.
Old 10-31-2014, 08:58 PM
SE120RG's Avatar
SE120RG
SE120RG is offline
grips are the same as all the other throttle by wire bikes. I'm interested in changing out the levers as well. might have to break down and buy the manual unless someone can explain it
Old 11-01-2014, 12:46 AM
onthelo's Avatar
onthelo
onthelo is offline
I did this on my 14 not too bad at all. Throttle by wire throttle side and the left side the grip is just glued on so you break the glue seal and slide the grip off then put the new grip on and set the allen screws it comes with. For the levers, the clutch just pull the hog ring off and then pull the pin out will come the handle but for the throttle side you need to remove the housing to get the tab out of the lever then same thing remove the hog ring pull pin and lever comes out and just reverse process to get them in. I will look around you tube I now there was a video of a guy doing one. It's not difficult but without the right tools and an extra hand those usually make it easier IMO
Old 02-22-2015, 06:07 PM
Curtazman's Avatar
Curtazman
Curtazman is offline
4th Gear
Default How did you remove the switch housing I cannot figure it
How did you remove the housing in the the throttle side?
QUOTE=onthelo;13376562]I did this on my 14 not too bad at all. Throttle by wire throttle side and the left side the grip is just glued on so you break the glue seal and slide the grip off then put the new grip on and set the allen screws it comes with. For the levers, the clutch just pull the hog ring off and then pull the pin out will come the handle but for the throttle side you need to remove the housing to get the tab out of the lever then same thing remove the hog ring pull pin and lever comes out and just reverse process to get them in. I will look around you tube I now there was a video of a guy doing one. It's not difficult but without the right tools and an extra hand those usually make it easier IMO[/QUOTE]
Old 02-22-2015, 06:42 PM
Onedef1's Avatar
Onedef1
Onedef1 is offline
For the throttle side you got to remove the clamp holding the caliper, gently remove the caliper/lever assembly, ( don't remove the cable, though) then you can access the switch housing.
Old 02-22-2015, 07:18 PM
mwegryn's Avatar
mwegryn
mwegryn is offline
Installation of the throttle grip is super easy. The left varies depending on what you are putting on. Some are glued, some are not, and some use set screws. The Avon's I just installed do not get glued on, they just seat in the switch housing. That was one of my deciding factors...that and they're made here in the US.
Old 02-22-2015, 07:40 PM
Stew Pidaso's Avatar
Stew Pidaso
Stew Pidaso is offline
You may be able to go onto the H-D store and click on the part you want to install. Click on the " more info" tab and a link to the instructions pdf file
mike_oh
04-15-2012 10:11 PM
Tri glide 10
01-23-2010 09:02 AM
wayne72472
01-19-2009 12:00 AM
lennyhd2002
11-14-2008 02:59 PM
Arctic Badger
General Topics/Tech Tips
07-17-2007 05:04 PM
Quick Reply: Grips and Levers
