GPS Round Trip Bug?
GPS Round Trip Bug?
I searched the forum and found no reference to this "bug" I seem to have on my 2014 Street Glide Special Infotainment Center. I have the 6.5" with the newest firmware 1.18.2 and recently noticed when I enter an address the system automatically routes me to the destination as expected but also starts up a round trip to bring me back to the starting point. I've tried to figure out how to eliminate the round trip and only go from point A to point B and no further. Once I get to point B then I want to decide where to go from that point.
I checked the settings under "Navigation Setup" and the area where you can select fastest, shortest, scenic, etc. has a Round Trip option but it is greyed out and I cannot check or uncheck it. By the way it is NOT checked but I still get a round trip when inputting an address.
Heading from Vegas to SoCal this coming Tuesday so need to get this fixed before then. Anyone have this issue and a solution?
Maybe you have "Home" already set as a destination and it's taking you back there every time you put another one in. Check to see if the NAV already has a route set to home. Click on the small box of lines near the center of your screen and then select "Stop". That will clear any routes that are active.
That was it! When I entered a destination the "Round Trip" was checked and greyed out so I could not turn it off. As you suggested I cleared the trip and went into the Nav Setup and unchecked the "Round Trip" and now all is well. That was the solution. Thanks much.
Not to hijack this tread because I just learned something from it but I have an issue I need help with. I was up in Vegas earlier this year and somehow got Red Rock HD locked into my home and can't figure out how to get rid of that so I can put in my actual home address, how do I clear this so I can enter mine.
Thanks
Thanks
