2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
2014 Half-Assed HD Garage Door Opener Install 91558-01B
Old 02-10-2015, 09:24 PM
load97's Avatar
load97
load97 is offline
Arrow 2014 Half-Assed HD Garage Door Opener Install 91558-01B
This is to help people install the garage door opener on their 2014 Touring bikes. The write up is a bit of an afterthought so I didn't take as great a pictures as I would have liked, hence the "Half-Assed" part. This was done on my 2014 Street Glide Special. No need to post about other openers, or what's cheaper, better, worse.
The directions for the 2014 Touring bikes are somewhat confusing since you would think the harness would be fairly plug and play; not to mention made for the 2014 Touring. This kit is really meant to be HD's jack of all bikes universal kit. I ended up having to extend the black ground wire with the included black wire that came in the bag, and shorten almost all the white wire.
I started by pulling the sheathing off the harness, as it doesn't do any good to be on at first. I then soldered the black wire from the garage door opener kit (bag) on to the garage door opener harness. It's now approximately 3' long. I cut almost all the white wire off the harness as I only needed 6-8" of it. I then soldered part of the white HD garage door opener harness wire to the blue/white headlight wire. I put male/female connectors on the white wire to disconnect it from the headlight later if needed. As shown in pic of leftover parts I didn't use. This left me with the orange wire & black wire I soldered on to the HD garage door opener harness. I then fed these two wires back through the sheathing (takes a little work).
Harness already installed under the outer fairing (3 pics):
Run the harness wires (now in a sheath) back down through the wire tray towards the left side cover. They will connect to the accessory plug wires that run up from the left side cover. First pic is the circled black & orange wires that are heading back to the wire tray on the neck of the bike.
Pic from the wire tray side showing wires in the sheath:
Left side cover removed. Pic's showing how & where the accessory plug goes (plugs in to the top port):
Accessory plug snapped in to place:
Pic's of the orange & black ground wire at the bottom of the wire tray. This is where they have to be connected to the accessory plug wires from the left side cover. I soldered my connections, but the HD kit came with crimp butt connectors. The orange wire was not quite long enough as I had accidentally shortened it I think. So all you see is the shrink tubing & black tape coming out of the wire sheathing. The orange wire gets connected to the violet W/blue stripe accessory plug wire. Then harness black wire to accessory plug black wire. The last wire just stays loose with the factory made cap on it. You will now have an extra HD accessory plug that sits in the battery compartment area for future use since the loose wires were connected to the HD garage door harness.
All the extra parts I didn't use (I soldered, instead of crimping), including all the extra white wire that I cut off:
The garage door receiver mounted in place. It connects to the same wires that are run over to my house garage door button located next to the man door going in to the house. The wire that my garage door opener used are harder wire, & HD's kit is stranded wire, so make sure you get it in the wire hole good. I at first wasn't making a decent connection since I was twisting the stranded wire around the other & it kept pushing out. Once I made a good connection, all was well.
The actual box with part number the HD garage door opener came in. Don't forget the accessory plug (not pictured):
Here's the link to the HD Garage Door Opener: http://www.harley-davidson.com/store...oor-opener-kit
Here's the link to the HD Accessory plug: http://www.harley-davidson.com/store...ion-update-kit
More (pic's) to come in this post.
load97's Avatar
load97
load97 is offline
Reserved.
Old 03-27-2015, 07:56 PM
penmaker's Avatar
penmaker
penmaker is offline
Do you have to remove the tank or the tank console to get the wire back to the accessory plug?
Old 03-28-2015, 04:47 PM
load97's Avatar
load97
load97 is offline
It might be possible to fish the wire through, but why? The tank pops off with 3 bolts and just pulls off (plus disconnecting console which is super simple). It's not like the softails where the gas line loops under the frame and becomes a small pain in the ***.
Old 03-28-2015, 09:53 PM
wlibert's Avatar
wlibert
wlibert is offline
I don't use my cigarette lighter so I just used the cigarette lighter wires for power.
Old 03-28-2015, 10:18 PM
Bikerscum's Avatar
Bikerscum
Bikerscum is offline
That's a great idea, thanks. I have an opener kit on the way.
Old 03-29-2015, 01:41 AM
highwayman1224's Avatar
highwayman1224
highwayman1224 is offline
Man that's a lot of work! My garage door opener sits in my left front pants pocket and when I get close to my driveway I press on my left front pants pocket with my left index finger and the door opens.... Lol
blap (01-04-2020)
Old 03-29-2015, 05:45 AM
TurkeyRun's Avatar
TurkeyRun
TurkeyRun is offline
Yup, I bought 4 of these for like $20 each and keep them in my pockets. Means I have a flash light with me all the time too :-D
Old 03-29-2015, 06:04 AM
mgibson61611's Avatar
mgibson61611
mgibson61611 is offline
Me too... That's the way I've done it for years. No need for all the fuss.
Cheers
Old 03-29-2015, 06:30 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Good write-up...can't blame a member for being thorough and crafty. I installed both of my garage doors when we built the place so having four of the openers made it easy to do the McGruber install w/button in batwing to opener stuck inside. Same concept as OP's deal, but no need for the little wireless interface module for mating to your opener.
Quick Reply: 2014 Half-Assed HD Garage Door Opener Install 91558-01B
