headlight bulb replacement
soooo, in order to save a few bucks and still get the "bright white Headlight"effect. Im looking to replace the stock bulbs with sylvania ultra brights or possibly a LED style bulb that replaces the H9 and H11 bulbs. My question is Can i do that? Will LED bulbs work with the reflector housing? Has anyone done this? suggestions?
you won't need any resistors that i know of, the ECM should recognize and correct the load as it does when switching the blinkers to LED. With all the new LED bulb replacements out there I'm thinking there may be a suitable replacement for the stock bulb that would work in the stock housing. And exactly how easy is it to replace the bulbs.. I can't find anything on-line that shows this.
Fuel Moto has a direct replacement but according to the note it will cause an error message.
http://www.fuelmotousa.com/moto-led-headlight-bulb.html
2014 FLHXS takes H9 and H11.
yeah,agreed... Utra-brights or a similar style bulb would be the safe route. How easy is it to remove the headlight? Is it just trim ring, 3 retaining bolts, and then the headlight just comes out?
If you keep and eye out, napa ran a sale last year in March and you could get a 7" LED truck lite for like $170 with a lifetime warranty. A lot more expensive than just a few bulbs, but far less than you'll pay for a true LED from Harley and much better light output than just an LED bulb in the factory lens. Just gotta build a harness to get to an H4 connection and it plugs in no prob. Just a thought in case you haven't heard of the swap. I get a lot of compliments on mine. The light when off has almost a black lens look, and it works worlds better than stock when riding.
Sooo... how easy, or whats involved in swapping out bulbs?
As long as Sylvania or whoever makes a bright white bulb in the factory plug style that's on our bikes, it'll just plug and play. I actually hadn't heard of the issues with dtc's mentioned here when installing different lights, but if you stick with a normal, just brighter, incandescent bulb, should be zero issues.
