2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Needs some quick help
Old 03-05-2015, 07:19 PM
goose222's Avatar
goose222
goose222 is offline
Default Needs some quick help
Guys looking for some help. I installed the led tail lights that mount to the bags that come with the quick disconect kit that is for my 2014 limited. Everything works fine but when I turn on my turn signals the green arrows on the dash rapid blink but both the front and rear turn signal lights blink at a normal rate. What in the world would make the green arrows blink faster than the lights themselves. Thanks in advance
Old 03-05-2015, 07:23 PM
mitchflhx's Avatar
mitchflhx
mitchflhx is offline
Are they custom Dynamics? I was told by them it takes a little while for the signals to, for lack of a better term, sync up.
Old 03-05-2015, 07:25 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
Mine did the same thing but after a week or two it corrected itself. As long as the front and rear indicators are signaling correctly, I wouldn't worry.
Old 03-05-2015, 07:45 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Try turning on your 4 way hazards for 5 minutes.
Report back.
SafetyMan's Avatar
SafetyMan
Report back.
Old 03-05-2015, 08:03 PM
a3dad's Avatar
a3dad
a3dad is offline
Report back.
Old 03-05-2015, 08:08 PM
goose222's Avatar
goose222
goose222 is offline
Thanks a lot guys. I will give it a try and report back. I was hoping it was a something simple.
Old 03-05-2015, 08:31 PM
jimmy1439's Avatar
jimmy1439
jimmy1439 is offline
I did the 4 way flasher thing a few times when I installed them almost a year ago. Have done it a few more times since. The green arrows still flash 4 times normal, then start flashing fast. The lights themselves have been flashing correctly every time I have leaned back and checked. FWIW, they work correctly when the T/P is installed. I quit worrying about it.
Old 03-05-2015, 10:10 PM
goose222's Avatar
goose222
goose222 is offline
Ok guys I am reporting back. Left the four ways on for 5+ minutes and it did not work. Jimmy = that's exactly what is going on with mine. I guess it's nothing to worry about so I will try and not let it bother me. Thanks again
Old 03-06-2015, 10:22 AM
rchop's Avatar
rchop
rchop is offline
Put the Key in on position and have your flashers on for about 5 MIN. With the CAM system installed by HD it will re program the flasher on its own. So no load equalizer needed... Thanks Harley Davidson. Best of luck
Quick Reply: Needs some quick help
