Which brings me to . . . Tuners for My 2015 Ultra LTD
I suppose I could go and pay top-dollar for the best . . . but that might not serve me well. I'd like a tuner to complete my stage one on my Ultra Ltd. So here are my criteria:
I've good experiences with the TFI Techlusion product that I purchased about 3 years ago for my 2011 Superglide Custom. I called the factory and they stated that the wiring harness and programming is substantially different so its not worth it to re-harness and reprogram the system. I can purchase a new one for $250.00 before discounts. What else is out there? Its been three years since I looked. Any help would be greatly appreciated . . .
Mark!
- Simple and Easy. I have no desire to squeeze every last bit of perfomance out of my bike using a dyno and etc. Simple and Easy is good.
- Doesn't require me to attach external devices to 'program' it. I'm a software engineer by trade, no programming. Period. While I ride - I ride.
- Less than 400.00
- A reasonably capable person w/tools ( me ) can install it (again, with no required programming via external device)
- And, of course - it keeps it rich and cool!!
Mark!
Last edited by markfsanderson; 04-18-2015 at 07:27 PM. Reason: Missed the obvious . . .
I guess I'm not sure what you mean by external and programming. Either way with a tuner, whether you dyno tune or not, it's an external device. One stays, one leaves. It will either piggy back or flash the ecm - both of which could be considered programming I suppose. So if I set aside my uncertainty as to what you mean, I will say Vance and Hines FP3 because it couldn't be any more simple, it's $300, and it does the job. It's what I chose because my needs are few. Plug it in, work through a few basic steps, and you're done. No need to auto-tune if you don't want to as the options you select in the menu make an immediate improvement.
Here in the Rushmore section the 2 tuners you hear the most about are the FP3 and the Powervision 2. The former is less money but has fewer options. The latter is more money but more adjustability. There are a ton of threads on both.
Mark!
Perhaps I should reconsider . . .
Look at the FP3, it looks like it might fit the bill. At only 335.00 on Amazon delivered 2nd day . . . this might be the best choice. No, I don't want to take it to a tuner . . . I just want to install something, make some adjustments and let it go. I need to look into this a bit more . . .certainly fits the budget and folks like it as well . . .
Mark!
Mark!
