2014+ Touring Models This Section Is For Rushmore/2014+ Touring Models Only
2014 air scope
Old 05-11-2015, 01:42 PM
myanoch's Avatar
myanoch
myanoch is offline
Default 2014 air scope
Did anyone have water going into fairing during bad storm
there is no seal at lower side of scope were fairing meets inner scope
Got caught in bad weather and it wet my garage opener which I have on top of plate above radio
Old 05-11-2015, 03:16 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
What is an air scope?
Old 05-11-2015, 03:21 PM
Melman's Avatar
Melman
Melman is offline
That's an instrument you use to magnify air!
Old 05-11-2015, 03:23 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
The FLIR in your infotainment...........you didn't know?
Old 05-11-2015, 03:27 PM
fattybob's Avatar
fattybob
fattybob is offline
Are you referring to where the inner and outer fairing meet in the air vent opening (i.e. air scoop)?
It would be nice, but I don't think any of the seals between the inner and out fairing are water tight.
skieverything's Avatar
skieverything
skieverything is offline
I thought it was that thingy ma jiggy on the side of the motor.......but then he said the radio tgot wet, and I was way more confused than originally.......
Old 05-11-2015, 03:56 PM
SafetyMan's Avatar
SafetyMan
I reckon he is referring to the fairing vent....
But I'm a smartass. I used to be a dumbass, but I studied hard and paid attention in class.
To answer the question, I've ridden in absolute downpours, and have never had an issue.
These machines were designed to be used outdoors.
Now if a man has taken something apart, and not reassembled properly, there could be a problem...
Old 05-11-2015, 04:33 PM
GlidingJoe's Avatar
GlidingJoe
GlidingJoe is offline
Water will enter the insides of the fairing for they are not sealed perfect. And a true leak point is the fairing vent, it is not sealed to the outer fairing. I know this for on my '14 SGS I had installed a Arc Audio Amp above the radio and washing the bike the water dripped into the amp, luckily it had circuit protection and shut down before any harm. I posted that in the Audio section and many were thankful for the tip to cover the amps that had top mounted connection or fans on the top. other folks found out the hard way as well. Everything factory H.D. in there is typically water proof.
Old 05-12-2015, 09:53 AM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
Now if would give us a water proof horn, that would be awesome!
Old 05-12-2015, 09:59 AM
myanoch's Avatar
myanoch
myanoch is offline
I mentioned it because of the issue of a add on mounted on that tray
will get wet.
I also believe there are electrical connections in the fairing that are not water tight.
It would have been easy for Harley to seal it.
They seal the windshield and the outer perimeter of the fairing
There is foam on the top half of the air inlet
Quick Reply: 2014 air scope
