My SGS turned into a jet engine.....
I do think just covering the bottom of the Clutch spring like posted above is correct. Some folks need to be reminded that this is done while the bike is straight up not on the Jiffy stand.
Yes, the level definitely needs to be set while the bike is upright (not on jiffy stand) to get it right otherwise, it will just stream on the floor.
It's possible that the tensioner adjusted itself way too tight and that's what's causing the noise. My brand new Limited was noisy as hell driving it home from the dealer when I bought it 4 days ago.
I took the primary cover off after it had cooled to room temp and the chain was WAY too tight. It took about 10 pounds of force to deflect it 1/8" and that's too damn tight!
Put in a Baker Attitude Adjuster and set the chain to 5/8" slack at the tightest point, as per instructions. Problem solved. Night-and-day difference. No more whirring and it shifts like my Dyna 5-speed now. Neutral is super-easy to find now, too, and shifts are more of a "click" than a "clank-bang".
Also put Redline V-twin lubricants in the Primary and tranny, so that may have helped also. Couldn't be happier!
Disclaimer: I am not in any way affiliated with Baker Drive train Inc. Just a totally satisfied customer.
It's possible that the tensioner adjusted itself way too tight and that's what's causing the noise. My brand new Limited was noisy as hell driving it home from the dealer when I bought it 3 days ago.
Put in a Baker Attitude Adjuster and set the chain to 5/8" slack at the tightest point, as per instructions. Problem solved. Night-and-day difference. No more whirring and it shifts like my Dyna 5-speed now. Neutral is super-easy to find now too and shifts are more of a "click" than a "clank-bang".
OK, so changed out the tensioner with the Hayden M6 and lo and behold quiet as a mouse. I added the additional oil (45oz.) with the bike in the upright position and took it out for a 50mi test ride and the damn thing was very quiet. I do hear a little chain lash again the inner primary when I rev the engine in neutral but nothing significant.
Whew, glad I got that resolved. Was starting to get a little concerned as to the cause but clearly the chain was too tight.
Again, thanks for all who responded.
Now, hopefully somebody will come out with an otherwise stock (and affordable) chrome primary cover with the inspection/adjustment port in it.
The brain-dead hack at the MOCO that came up with that less-than-worthless, POS auto-adjuster should get his *** kicked daily for life for putting it on such a great bike.
I wonder how many millions of dollars that piece of junk has cost the MOCO in warranty repairs since they introduced it in '06?
One thing's for sure, I would never have bought my '15 Limited if the Baker unit wasn't available!
Again, I am not affiliated with Baker Drive Train in any way, just a very satisfied customer.
