Plug or Replace tire
#31
#33
#34
The mushroom plug on the Stop and Go kit is installed with the use of 30W motor oil on those plugs. Oil is needed so the plug will slip thru the insertion tool. This means the plug is still coated with oil as it sits in the hole in your tire. There is no vulcanization or any type of glue to hold it in place, so the only thing holding it is friction, and air pressure inside the tire. If you hit a rock at the point of the plug, there's a good chance that plug will pop out of the hole, to the inside of the tire, and the tire will go flat.
For the above reason(s) I stopped using that product.
I recommend a kit that uses strings. Not just any strings, they have to be the type that vulcanize (chemically bond to the rubber of the tire). The string kits you get at your local auto parts store use rubber cement, which does not vulcanize, so you get a repair that is marginal.
The BestRest kit uses vulcanizing strings that were designed for the trucking industry. They chemically bond to the tire and become "one with the rubber". If they can keep air in a tire on a 100,000 pound semi blasting down the road at 80MPH, they'll work in your motorcycle tire. I use them on the road and on the trail with my dirt bikes. They've never let me down. The mushroom plugs have.
https://www.bestrestproducts.com/p-2...epair-kit.aspx
#35
#36
#37
1. Stop N Go doesn't provide glue with their kit (s). There is no adhesive or vulcanizing compound provided, so you must've used something else.
2. They do use 30 weight oil to lubricate the plugs. We bought them in bulk and repackaged, and we added the oil per Stop & Go recommendation and protocol. Oil is needed to insert the plugs or they will tear apart.
I know these points to be cold hard facts. I used to sell and demonstrate thei mushroom plugging kits at various rallies. I stopped selling them because of the reasons I described above.
I'm glad your Yukon episode had a happy ending, but I don't think other readers would be served if they didn't have all the facts.
Vulcanizing strings can repair 99% of all punctures. For the remaining 1% the strings can be put in side by side for those larger holes.
#38
I've used these patches with 100% success for decades. http://safetyseal.com/catalog/index....products_id=77
The kit packaging in the link is new (I just ordered one for my '15 Limited) but the basic product(s) it contains have been around forever.
I also use a foot operated, compact Mini Foot Pump - that I just found out is no longer made, which sucks - instead of an electric unit.
#39
2. They do use 30 weight oil to lubricate the plugs. We bought them in bulk and repackaged, and we added the oil per Stop & Go recommendation and protocol. Oil is needed to insert the plugs or they will tear apart....
I can surely see that adding oil to the plugs would NOT be a good thing; guess that's why I don't add it and don't see in the instructions in my kit where it's recommended. All my plugs are dry, not oily. You are correct, no vulcanizing glue provided with the kit, the glue was bought separately. If people want to use string to plug tires, that's their business. I'll stick with a tire plug thank you.
