Adjust passenger headset volume from up front?
I am using a Sena SM10 Bluetooth transmitter plugged into the front DIN connector to send the bike's audio and GPS to my Sena wireless headset. I'd like to use the rear DIN connector - reroute it into the tourpack so the SM10 has power, signal and is concealed. But... I think the only means of controlling the rear DIN headset connector is through the passenger volume control switch on the right side of the seat.
I've looked through the setup and don't see any means of controlling the rear headset volume from up front. Has anyone run across this before and know of a way to do this?
It's too bad that HD missed the boat on this by a) not providing HFP with their Bluetooth, and b) failing to offer even a proprietary wireless headset that interfaces with the Rushmore models.
Yes and yes. Pair the SM10 to your 20S and feed the SM10 audio from the bike. Intercom functionality is not affected by Bluetooth connections.
In regards to my original question, I think the answer is NO. The only way to adjust the passenger headset output from the rear DIN connector is by using the v/c on the right-side backrest. The front connector on the tank could be routed back into the tour pack, and I'm considering doing that. Or, leaving the front connector in place as is, disconnecting the wiring (or adding a new cable in parallel) and running this into the tour pack.
One final thing, which I know has been brought up before -- when using the accessory power jack in the fairing to power 12VDC to the SM10, there's a fair bit of induced electrical noise. This does not occur when running the SM10 off the battery. Unfortunately, I've found the SM10's battery life to be significantly less than that of the Sena headsets (only about 5-6 hrs), so there's a tremendous convenience in running it off the bike's power. I'll probably look for a ground loop isolator to eliminate this noise.
