2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
intercom, cb question
Old 07-13-2015, 06:43 AM
wojo1965's Avatar
wojo1965
wojo1965 is offline
Default intercom, cb question
Ok, I have a 14 limited and and could swear that before the latest software update when I set the intercom and cb to come through speakers instead of the headset it would do just that but after the update even if its set for speakers I can only hear communication through the headset, am I wrong? If the option is there shouldn't it work, what am I missing? I would like to be able to set the intercom through the speakers for highway speed travel, to hear better, I wear a 1/2 helmet and with the highway speed noise my passenger has to almost yell for me to hear her.
Any advice will be appreciated.
Wojo
Old 07-13-2015, 07:07 AM
bigrobtemp's Avatar
bigrobtemp
bigrobtemp is offline
Wojo
Check the VOX level. Maybe that will help? I notice if it's not turned up enough we have a hard time hearing each other. Go back an update and see if that solves the problem? I have 18.3 if you want to try that.
Old 07-13-2015, 09:59 AM
Hammz's Avatar
Hammz
Hammz is offline
Wojo
The intercom never worked via the external speakers, only via headset.
That said, you may have been able to hear the sidetone through the speakers on older versions of the SWDL, but as I understand (still running 1.18.3) the sidetone was removed in 1.19.0 & 1.19.1 versions. Sidetone is the function that allows one to hear what is going in the audio input to the radio system; a monitor if you will.
Old 07-13-2015, 11:08 AM
wojo1965's Avatar
wojo1965
wojo1965 is offline
Thanks for the info.
Wojo
bigred333
09-29-2016 07:46 PM
Bruin08
09-09-2013 12:45 AM
One Terrific Hog
04-12-2012 07:19 AM
Geezr Glidr
Audio Systems
02-21-2012 11:06 AM
TheRainMan
08-26-2010 05:20 AM
Quick Reply: intercom, cb question
