2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
air wing luggage rack led install
Old 07-21-2015, 01:56 PM
benson1603's Avatar
benson1603
benson1603 is offline
Default air wing luggage rack led install
i'm going to buy a tour-pak rack light kit (p/n 68000112) to install on the luggage rack i just bought for my '14 streetglide special. i recently purchased the king tour pack and a detachable mount for it. the installation instructions seem pretty straight forward but the one concern i have is where the wiring exits the body of the tour-pak. step #13 says to remove the grommet from ,what appears to be the front of the tour-pak. there is no grommet currently on the pak. does that mean i need to drill a hold for the new grommet? on the bottom of the new pak there is what i'll call or what looks like a "knckout". looks like about a 3/4" circle "PARTIALLY STARTED" at the pak bottom. hopefully, i attached the install sheet so any advice would be appreciated.
thanks.
-J05847.PDF
Old 07-21-2015, 04:48 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
I'd say it has to be drilled.
Buy a black air wing, I'll swap you straight up for a chrome one with the LED in it already.
Couple of marks from my flag mount for PGR missions, but otherwise excellent....
I've got the LED tail light, and CD FillerZ, can't really see the air wing light on mine.
Old 07-21-2015, 05:53 PM
Yukon42's Avatar
Yukon42
Yukon42 is offline
After you drill the hole get yourself a grommet from Lowes or Depot to slide the harness through to keep it relatively weather tight.
Old 07-21-2015, 06:55 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
Drill baby drill.
Rubber grommet. Get one that already has a hole in the center vs solid
Old 07-21-2015, 10:03 PM
Seventy4blazer's Avatar
Seventy4blazer
Seventy4blazer is offline
The airwing light kit comes with the grommet. You will also need to splice in a wire harness from under the seat to the TP, then buy the wire harness from inside the TP of an ultra or limited.
I dont have the part numbers handy right now, and still need to finish the project myself. that will happen in September.
Old 07-21-2015, 10:44 PM
netwon's Avatar
netwon
netwon is offline
Originally Posted by bigskyroadglide
Drill baby drill.
The LED kit purchased from HD should include the required grommet. I will check my new tour pak and let you know if it has the hole already drilled or not.
Old 07-22-2015, 12:08 PM
Seventy4blazer
No holes in it except for the back rest and hinges that are already attached. I didn't notice a "marked" area for the hole to be drilled, but I didn't look too hard yet.
Old 07-23-2015, 11:38 PM
netwon's Avatar
netwon
netwon is offline
Sorry to forgeting to get back to you been working too many days in a row... Mine is not drilled on the bottom.
BIGRSRK08
Touring Parts
02-18-2018 08:31 AM
plutnicki
02-27-2012 09:34 AM
2010 Raffel Road King
01-29-2011 09:54 AM
shortride
01-18-2010 08:40 PM
Daves Not Here!
01-15-2009 09:34 AM
Quick Reply: air wing luggage rack led install
