Loose Steering Stem Bearings
I know that HD has a problem with the steering stem (fall-away) not being tightened properly from the factory.
So much so, when I explained to my parts guy what I was feeling on my brand new SB, its the first suggestion he had.
Sure enough, took it in to have it checked and BAM, fixed.
Saved me the $ I was gonna spend on a steering damper.
Your question leads me to believe yours has been adjusted and keeps coming loose.
Is that the case?
Is that the case?
Is that the case?
Is that the case?
To be clear, I'm no expert on HD's.
All I can think of is maybe the bearings or bearing races are going to sh*t.
Its strange to think the stem is loosening all on its own.
Hopefully someone will chime in that knows better than I.
Good luck on your trip to Sturgis (priorities man).
You've got quite the trek in your immediate future.
Hope its safe and uneventful... at least until the beer starts flowing.
Guess I should have mentioned that it's totally smooth, nothing like a bad bearing. And no slack when I try to shack the forks fwd and aft. I started the thread before putting her on the jack, just freaking out about the trip. Thanks guys
