2014+ Touring Models This Section Is For Rushmore/2014+ Touring Models Only
High pitch whine ????
Old 08-02-2015, 07:25 PM
ultraclassic53's Avatar
ultraclassic53
ultraclassic53 is offline
Default High pitch whine ????
I've got a a 2015 cvo road glide. I'm out at Sturgis enjoying the ride and today I noticed a high pitch whine. It seems to do it mostly on decel and and coasting, it stops doing it when I pull in the clutch. Doesn't do it while idling ? Hard to tell where it's coming from because it only does it while I'm riding . Any guesses ?
Old 08-02-2015, 07:34 PM
Silvertrain1025's Avatar
Silvertrain1025
Silvertrain1025 is offline
If i understand you correctly it may be because your in 1st gear. It will probably be be answered in more detail from someone else but it's that 1st is cut different then the other gears.
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is online now
First gear only? They all whine in first gear, I think something to do with the way the gears are cut....
Old 08-02-2015, 07:36 PM
dawg's Avatar
dawg
dawg is offline
Received 2,938 Likes on 1,701 Posts
Wife on back?
Skye120 (04-06-2020)
Old 08-02-2015, 08:00 PM
ultraclassic53
Yes girlfriend on the back. She rides with me a lot. I don't think she will be willing to run along side to see if she can here where it's coming from Just finished eating . I'll take I for another ride for some more testing .
Old 08-02-2015, 08:05 PM
tpcowfish's Avatar
tpcowfish
tpcowfish is offline
Mine just started it too, no
Old 08-02-2015, 08:08 PM
ramblin5's Avatar
ramblin5
ramblin5 is offline
You may have missed the point of his question. But then again, maybe not.
Old 08-02-2015, 08:10 PM
pFlarey's Avatar
pFlarey
pFlarey is offline
First and fifth are straight cut or spur gears. The others are helical or they are cut at angles. Straight cut gears are noisy. If you've ever owned an evo, you probably noticed it coming from the cam compartment, as they are gear driven.
Old 08-02-2015, 08:23 PM
Sailrider 1's Avatar
Sailrider 1
Sailrider 1 is offline
My 15 CVO Road Glide does the same thing. I don't think it's anything to be concerned about. I also think it's the straight cut gears. Red Line shockproof heavy in the trans will make it a little quieter but won't eliminate it.
Old 08-02-2015, 09:15 PM
ultraclassic53
Ok, rode it back after dinner and I have to change my story. It does it in 1st 2nd and 3rd but I also noticed right when I start to accelerate I hear a bit of a rattle. I'm thinking it might be a heat shield. Instead of a whine it might be a very rapid Tinney rattle on decel and it on accel it is just a more pronounced rattle . In the morning after it cools down ill check the exhaust out and see if there is anything loose or rubbing.
Quick Reply: High pitch whine ????
