2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Motolights installed
Old 08-05-2015, 12:18 PM
Nickblink's Avatar
Nickblink
Nickblink is offline
Default Motolights installed
Attachment 439306I have installed a set of chrome motolights with high power led. I contemplated to install the HD crash bar Fog lights, but I thought the installation is bit clumsy so for few dollars more I went with caliper install. The installation is much cleaner and relatively easy to install. The only parts I got from HD to do the installation was the dash switch $16 and a cable 69200722 $23 that I had to relocate a pin in order to work with the dash switch.
Attached Thumbnails Motolights installed-image1-4-.jpg   Motolights installed-image2-1-.jpg   Motolights installed-image3-1-.jpg
Old 08-05-2015, 12:46 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
Looks good. Can you get some pics at night with the lights on?? Do you see much difference riding in darkness??
Old 08-05-2015, 12:55 PM
Nickblink's Avatar
Nickblink
Default Additional pics
Well, I have all LED so it is like day time at night. I am attaching a pic inside the garage.
Old 08-05-2015, 02:04 PM
CanonSterVA's Avatar
CanonSterVA
CanonSterVA is offline
Interesting location.
Will have to look at those.
Old 08-05-2015, 03:13 PM
KMC1's Avatar
KMC1
KMC1 is offline
I was looking at these a few weeks ago, but didn't pull the trigger yet. I'm looking for lights to fill in the sharp cut off in the LED headlights when going around corners - I'm curious specifically if these have a more circular beam pattern that fills in those holes?
Old 08-05-2015, 05:42 PM
Nickblink's Avatar
Nickblink
Default Misc
These lights are driving lights, so the lighting patern is round and unlike some other LED like Custom Dynamics cool magic they have a 10* angle vs 30* and light is wide spread. As far as comparing them with the HD fog lights the motolight projection is by far much longer and not just a flat horizontal line
Old 08-05-2015, 05:56 PM
GlidingJoe's Avatar
GlidingJoe
GlidingJoe is offline
What is your opening attachment.... It is not working. Nice set-up!!!
Old 08-05-2015, 11:17 PM
KMC1's Avatar
KMC1
KMC1 is offline
10 degrees is pretty narrow, which is one of the main reasons I didn't think they will do what I want. Any chance of you taking some pics of the beam pattern and compare to stock? Maybe up against a building or something so it will show the height of the circular pattern?
Old 08-06-2015, 05:30 AM
Nickblink's Avatar
Nickblink
If you want wider pattern you can easily replace the these LED with Custom Dynamics cool magic. I think they are wider but shorter on distance.
Baja38ss
Screamin Eagle CVO Models
10-28-2018 10:37 PM
ElGigante
Touring Parts
02-11-2015 02:38 PM
hemi1300
11-15-2014 01:21 PM
shonrt1
07-18-2013 09:23 PM
fmnspooch
02-10-2012 09:23 PM
Quick Reply: Motolights installed
