Right cooling fan not coming on
On two occasions after shutting the '14 Limited down, the left cooling fan runs but the right does not. Took it to a dealer that confirmed the fan is operational, but it did it again afterwards. I have also done the manual turn on with the throttle and both fans come on but the right hesitates a second or two after the left.
Has anyone else had this problem? Any ideas?
I'll take it to a different dealer but would like an idea of what we're dealing with. Thanks.
Good luck getting it fixed, especially since you have rely on Harley "techs" to figure it out!
Vernal, thanks very much for posting that. I only have the 2014 Service Manual. I'm just not good enough on electrical to mess with it much. I can run wire and take connectors off and on but that's about it.
Is there anywhere that shows the electrical path when you do the manual turn on of the cooling system. I'm wondering if it completely bypasses the ECM and relays. I'm guessing it would, but I suppose there's a chance it tricks them.
Thanks again for your help.
The electrical path is the same for either normal or manual operation. The circuits are activated (turned on/off) by the ECM in both cases.
I like the idea of documenting it with a video, hold a little ribbon by the vent to show air flow.
Good Luck
Good morning. You haven't identified your fan brand but if it's Love Jugs there is no need to bring it to a dealer. In the event of any problem simply e-mail steve@love-jugs.com and we will take care of it for you. In the rare event that a fan is disabled for any reason I will immediately send you a FREE replacement. Love Jugs are designed for a simple plug and play replacement that any rider can do without the expense of hiring a mechanic. If you have a Love Jugs product I want you up and running ASAP so you can enjoy your cool ride. Our service matches our superior products.
Great customer service though!
