2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
New 2015 Ultra Limited - First Contribution Garage Door Opener
Old 09-29-2015, 11:00 PM
akakillroy's Avatar
akakillroy
akakillroy is offline
Default New 2015 Ultra Limited - First Contribution Garage Door Opener
Greetings! This is my first real contribution here. Owned a 1999 Ultra as well as a 2005 VRSCB. Traded both in on a 2015 Ultra Limited - Radioactive Green.
Been doing some mods, including tour pack quick release, customs license plate bracket and now the addition of a garage door opener.
I didn't want to pay the stiff price tag for the HD version that connects to the high beam flasher, with the additional wiring in the garage for the opener. I knew there had to be a better way, and cheeper.
Most all my 4 wheel vehicles had the homelink system, so I did a little research and discovered you can buy these modules on eBay cheep! ($15). So I ordered one up and since I was going to eventually add some other accessories I bought the $80 accessory switch kit to add the additional buttons to the dash.
Next (after figuring out where the wiring harness went, cuddles to DH for making connecting accessories a snap!) I modified the Homelink transmitter with a jumper to permanently press one of the homelink buttons, I then supplied power to the module, erased any codes that may have been in it (they provide you instructions for programing, in your vehicle owners manual, in my case the bay merchant included instruction with my purchase), then proceeded to program the single button. Once programed I disconnected the power and wired the module to the low amp accessory cable. I then modified one the acc switches to act as a momentary push button by removing the tiny actuator held in place with the switch spring, then popped it back in the switch holder. tested and whala! I tucked the harness and stuck the module in a rubber glove to keep it safe from water and done, one of the easiest mods I ever done. See the photos below. if you want any other information just ask!
Old 09-29-2015, 11:03 PM
akakillroy's Avatar
akakillroy
Additional photos
Old 09-30-2015, 09:09 AM
markfsanderson's Avatar
markfsanderson
markfsanderson is offline
Looks Great! I'm very interested in the detail about converting the accessory switch to a momentary . . .
Thank!
Mark!
Old 09-30-2015, 09:35 AM
J929626's Avatar
J929626
J929626 is offline
To convert the button to momentary (it does not lock on the down position) remove that little clip in shown in the third picture.
Old 09-30-2015, 09:48 AM
caddman's Avatar
caddman
caddman is offline
I have been looking for a way to do this for years! This is awesome!
Old 09-30-2015, 12:24 PM
akakillroy's Avatar
akakillroy
Yes, just hold the switch (its actually just a slide, the switch is in the housing where the button mounts) holding with your index finger and thumb depress the spring and the turn upside down and the little wire actuator will fall out, then release the spring, your done ;-)
Old 10-01-2015, 12:47 AM
txm8de's Avatar
txm8de
txm8de is offline
Attachment 445423
Attachment 445424
Attachment 445425
Attachment 445426
Attachment 445427
Where did you get your fog light switch?
Old 10-01-2015, 01:26 PM
akakillroy's Avatar
akakillroy
Fog switch, the existing switch was there for the driving lights, all I added was the two AUX switches that came with the kit.
Old 10-01-2015, 05:33 PM
bill_1202's Avatar
bill_1202
bill_1202 is offline
This is a great post! Thanks!
Old 10-01-2015, 07:46 PM
TexasMotorcycleRider's Avatar
TexasMotorcycleRider is offline
Default Bam!
Take out the foam in the cubby, get some industrial velcro tape, use regular garage door opener. I have had this for over a year with no issues. Cost, $0.15.
Velcro tape a garage door opener inside the cubby.
Quick Reply: New 2015 Ultra Limited - First Contribution Garage Door Opener
