....you guys that run ATF in the primary; when you go to trade, do you tell the dealer that you have been using ATF or do you change it out to primary oil? If you inform the dealer, do they grouse about it or say nothing?
I wouldn't feel the need to say, or not say what's in there. Or what trans lube I used, etc. If they want to know they can take it apart. I doubt they really care, but service records would be a plus at trade in time I would think.
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
I use ATF and would not feel obligated to say but if asked I would be proud to tell them and how well it works. Been using it for over 15 years now and will never use anything else.
