2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
S/E Stage III 103 Upgrade Kit
Old 12-15-2015, 05:51 PM
jbrooksca's Avatar
jbrooksca
jbrooksca is offline
Default S/E Stage III 103 Upgrade Kit
I am thinking of having the S/E Stage III 103 Upgrade Kit #92500028 installed this winter on my 2014 Ultra 103 H/O (air cooled). The dealer has also recommended new S/E roller lifters and the S/E cam support plate and oil pump. I already have a HD stage l air cleaner & download, Vance & Hines Power duals and S/E 4" Street cannons.
I typically ride two up and packed. My normal shifting range is 3000 to 3500 rpm. It looks to me that if I shift at 3500 the rpm drop should put me at peak torque using the attached chart.
I can have this kit installed and be covered by the ESP. I am not interested in going non Harley parts for this reason and not interested in the 110 kits .
Has anybody installed the S/E 585 cams and what do you think?
Thanks
Jerry
Attached Thumbnails S/E Stage III 103 Upgrade Kit-se-103-kit.jpg   S/E Stage III 103 Upgrade Kit-se-camshafts.jpg
Old 01-05-2016, 01:42 AM
MichaelSG's Avatar
MichaelSG
MichaelSG is offline
I just did the SE Pro Stage III in my 2015 SG. Don't know the HP and TQ numbers yet. Still in storage due to winter. I did however go and rev it up in the shop a little bit and the sound is awesome. Gateway HD in STL has been running the dyno on 2016 SG's with Stage I at 90HP so I am hoping to get 100+ after the tune. With the 585 cam I am hoping for TQ in the 110 range. From everything I have researched till my head explodes the tune means as much as about anything with the 103 and a Stage anything build. I have a buddy that spent 7500 on a Trask putting out 132hp and 149tq but that was also 7500 and most likely more than I need. I will let you know when I get mine on the dyno. Probably March tho unless we get good weather on the weekends in STL. Hope that helps my friend. Happy Riding.
Old 01-05-2016, 12:05 PM
bill_1202's Avatar
bill_1202
bill_1202 is offline
Keeping up with the Jone's? Stock 103 is ok with me with plenty of power. Now in my younger racing days...
Old 01-05-2016, 05:42 PM
MichaelSG's Avatar
MichaelSG
Ha! I don't know about the Jone's there is never a place to stop..That is why I stopped where I did. The 103 is great stock. I have spent the last few years riding a stock EVO in a '99 Heritage. Still enjoy riding that one too. Good looking sled bud. Like the Blue Pearl real well.
Old 01-05-2016, 06:36 PM
Maddog94's Avatar
Maddog94
Maddog94 is offline
I have about the same setup, but with 2-1 and ended up with 96/111. It is awesome pulling away from the line. I am happy with it, don't need any more power or I could get in trouble.
Old 01-05-2016, 08:13 PM
MichaelSG's Avatar
MichaelSG
Nice numbers. The exhaust is what I am hoping doesn't hold mine back but I definitely like the sound of the V/H's We shall see. Good lookin' ride man. It may be a few months before your riding in IL. Supposed to be some cold weather coming.
Old 01-05-2016, 08:25 PM
Longridertx's Avatar
Longridertx
Longridertx is offline
I don't believe you will need the SE cam plate and oil pump. I would put in new lifters though. I just had Woods TW 777 cams and SE lifters put in on my 15 Ultra and there is no problem using the stock cam plate. Would have put in S&S lifters but didn't want to wait on them to come in. There are also other cam choices out there as well.
'05Train's Avatar
'05Train
'05Train is offline
You need to ask yourself a serious question....Is the couple more horsepower and lb-ft worth the money you're going to spend? You're talking about a 900 pound motorcycle, mind you.
The kit you're talking about is going to run you several thousands of dollars and give you zero return when you sell or trade-in. And your bike is not going to be appreciably faster, especially if you're shifting at 3000-3500 rpm.
For my money, the best things you can do for your bike are a good Stage 1, and then do good suspension. The Stage 1 is simply the best bang-for-the-buck you're going to see power-wise, and an upgraded suspension is appreciated every time you ride, on any roads, given any riding style.
Your bike, your money, but the minor power bump you're going to see with that kit will likely disappoint you.
Old 01-06-2016, 10:25 AM
Maddog94's Avatar
Maddog94
Maddog94 is offline
Thanks. I rode in December for the first time and it was fun, but now I think the bike is going to be covered until spring.
Old 01-12-2016, 07:44 PM
ABuck's Avatar
ABuck
ABuck is offline
I saw the results posted up today at the local dealer for an install on this kit. They we're still tweaking it a bit.
The run before the install was 78/100 with a stage 1 and rush slip ons.
The run after the kit installed, a heavy breather, a screamin eagle tune and rush slip ons was 90/115.
I'm guessing with no cats or better exhaust you'd get more hp out of it. They said that's about where it should be for tq.
Quick Reply: S/E Stage III 103 Upgrade Kit
