Bel-Ray oil line
I use Syn-3 in the engine still and have since the first service. at 62k on the Street Glide now. At 20k I switched to Bel-Ray primary and trans fluids. Shifts smoother and goes into neutral easier. zero complaints, so when it was time for the 1k service on the wide glide I started using the same. Very happy with it. I can notice the difference when they have filled the primary with syn-3 after warranty work.
The dino trans fluid is the best I've tried, & I've tried a lot.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Have Bel-Ray in both primary and trans. Only oil dealer sells other than HD brand. Trans noise is quieter, shifting is smoother and it's definitely easier to find neutral. The oil appears to be thicker than HD primary and trans oil. Only minor gripe is the bike likes to lunge a little forward (clutch friction) when starting up cold. But this only lasts for a second or two.
