Faulty CD Fillerz removal
04-10-2016, 01:32 PM
As the title says. Whats the best, least damaging way to remove a faulty fillerz led?
04-10-2016, 02:24 PM
Quote:
Originally Posted by
weezer_nd
Are they double stick taped? If so use a heat gun carefully, and maybe some dental floss if you can get to it.
04-10-2016, 03:43 PM
Yeah, double sided tape on chrome.
04-10-2016, 03:56 PM
weezer_nd
Heat gun, and if you get the gap to open up spray some WD-40 in there.
04-10-2016, 04:03 PM
I agree the heat gun is the way to go plus fishing line.Dental floss breaks to easy.Not going to hurt the chrome underneath.
04-10-2016, 05:51 PM
04-10-2016, 10:29 PM
Is CD replacing these under warrantee?
04-11-2016, 05:53 PM
Mine acted up last year and CD sent me a module to add to the harness to fix them. They had a bad batch that the brake lights would fail. Mine has worked fine every since.
04-11-2016, 09:01 PM
Didn't need to remove them after all. Some wires in the pin connectors were put in the wrong holes. So they wouldn't match up with the functions on the instruction diagram.
Swapped them after the tech guy emailed me a color matching diagram.
WOW, are these things bright!!!!
04-12-2016, 09:06 AM
Im glad you got it figured out. I love mine. They definitely get noticed during the day, and at night the cars stay way back.
