AKE Bluetooth Adapter & Sena SM20s Issues
Hey folks, trying to get the AKE Bluetooth Adapter for Harley working w/ my Road Glide Ultra and a Sena SM20s headset and have run into an issue.
I get audio fine from the radio and other audio sources, but seems I can't transmit. I've confirmed the AKE dongle is in 'duplex' mode, single green led on the adapter. Headset is paired with the AKE, I've even forced HFP pairing mode on the headset to ensure it uses the right bluetooth profile.
Firmware versions on the headset and radio are the most current versions, 1.6 for the headset and 1.19.2 on the Boom radio.
I've got an email in to AKE but wanted to ask here as well in hopes one of y'all ran into similar issues or have any insights on what to try next...
So, any thoughts?
So, any thoughts?
Bluetooth pairing
i get confused with the different Bluetooth profiles but try connecting just like you were connecting it to your phone. The video below is me connecting mine and the steps I use. I have a different sena product so I can't speak to the specifics of the SMH20 but I just hold the phone pairing button until it says, "phone pairing". Then it's good to go stereo and duplex. Check out the video I made for reference on pairing and deleting old pairings.
So, any thoughts?
So, any thoughts?
twhayes99 (04-26-2016)
http://youtu.be/lLENFbIFgZE
Don't think I experimented with the pairing or power on order, I'll give that a shot later and see if anything changes.
Appreciate the info!!
Thanks for the input CPT, I did try the default method of pairing the first few times though, when that didn't work I thought perhaps it was pairing with an oddball profile on the Sena so tried the force to HFP method. During all that I cleared all pairings multiple times from both the AKE and the headset as well.
However, phone calls aren't working. I can hear them fine but they get no audio from my side. I suspect this may be an issue in the BT connectivity between the head unit and my phone, rather than the AKE dongle, since voice commands are functioning so more experimenting is necessary.
To bad CB is mostly dead these days, at least around, here that could be another test
Partial success!! Audio is at least now being received by the head unit from the headset, I can get voice commands functioning so that confirms tx is happening.
tda69
03-30-2008 05:24 PM
