SGS 2014 Tour Pack Rear Light
My wife has a 2014 SGS that she has added a king tour pack for our long distance trips. She is now wanting to add a rear running/break/turn light bar (similar to the lights on my 2014 Ultra Limited tour pack). I've searched thru the forums and internet unable to locate a rear light bar specifically designed for the 2014 and newer tour packs, short of ordering from HD parts ($$$). I seem to find light bars designed for 2013 and older tour packs (different size than the 2014). I'd greatly appreciate any help or advice on where to locate a rear light bar that will fit the 2014 tour pack.
This is a setup I did for my SGS. I had bought the tinted lights from PA catalog and purchased the king tourpac wiring harness from the OEM catalog. Other than cutting holes and matching up the connectors, it was fairly simple, but expensive. I also did the rear speakers which, IMO, look better with the tourpac back rest. Not to mention, the upgraded amp and four speakers setup sounds great!
I'll look for the part numbers if you interested in this setup for the lights.
this is a setup i did for my sgs. I had bought the tinted lights from pa catalog and purchased the king tourpac wiring harness from the oem catalog. Other than cutting holes and matching up the connectors, it was fairly simple, but expensive. I also did the rear speakers which, imo, look better with the tourpac back rest. Not to mention, the upgraded amp and four speakers setup sounds great!
54352-09 kit, smoked sidemarker light
69200131 wire harness, t-pak
This is a setup I did for my SGS. I had bought the tinted lights from PA catalog and purchased the king tourpac wiring harness from the OEM catalog. Other than cutting holes and matching up the connectors, it was fairly simple, but expensive. I also did the rear speakers which, IMO, look better with the tourpac back rest. Not to mention, the upgraded amp and four speakers setup sounds great! I'll look for the part numbers if you interested in this setup for the lights.
I wanted this in the past but my local dealer was hesitant to do it exactly because there was no template for drilling the holes.
Went with the small light in the luggage rack on top of the pac instead, not nearly as visible but a whole lot cheaper....
SCREW,PAN HD TORX,#8-16 X 9/16 - 10200133
