2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Tools needed to swap lower legs?
Old 07-28-2016, 11:26 AM
jcmer22's Avatar
jcmer22
jcmer22 is offline
Default Tools needed to swap lower legs?
I have a set of powdercoated lower legs that i need to swap over to my forks and im curious what tools are needed to do so? Earlier this year i pulled the forks and had a local indy install the progressive monotube kit, but this time around id like to do it myself. im very mechanically inclined and I have a shop manual.
What tools are need to pull the lower legs off the fork tubes?
Im assuming ill need to replace the bushings and seals? does it come as a kit?
Thanks for any help!
John
Old 07-28-2016, 11:35 AM
Bunker's Avatar
Bunker
Bunker is online now
John
19mm Hex Socket
12mm LONG Hex Socket
Fork Seal Seater
You can make your own tools...
19mm head bolt and 2 nuts
12mm Hex wrench cut of the "L" portion and use a 17mm socket
2" PVC Pipe
John
I just got done with this, didn't install new seals mine were fine.
I installed the Progressive Cartridge, you may need something else to get the springs in if your putting stock back in.
Old 07-28-2016, 11:38 AM
jcmer22's Avatar
jcmer22
jcmer22 is offline
Originally Posted by Bunker
19mm Hex Socket
17mm LONG Hex Socket
Fork Seal Seater
17mm Hex wrench cut of the "L" portion and use a 17mm socket
2" PVC Pipe
im swapping the monotubes back into the new lowers.
just to verify, I thought it was a 12mm long hex socket?
Old 07-28-2016, 12:38 PM
Shadowray's Avatar
Shadowray
Shadowray is online now
Yeah I'm pretty sure I used. 12mm on my 15 SGS for the lower bolt.
Old 07-28-2016, 02:51 PM
Bunker's Avatar
Bunker
oops!
yes it is 12mm
edited original post
69cj
04-16-2016 09:02 AM
MartinSporti
03-13-2015 07:24 AM
run1fsr
11-23-2014 03:29 PM
luvtoride
04-19-2010 05:04 AM
mojo
06-22-2006 05:53 PM
Quick Reply: Tools needed to swap lower legs?
