2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
auxiliary light bulb
Old 08-19-2016, 09:32 AM
REGGAEX's Avatar
REGGAEX
REGGAEX is offline
Default auxiliary light bulb
1 of my auxiliary light bulbs blew out. harley sells the whole bulb and lens for $69 but not the bulb ? took it apart the rubber cover is glued on but i got it off ripped it some .The bulb that is in it is a h3-35w has clips just like any other bulb came right out is there a reason just the bulb can't be replace the rubber cover is not sealed had a big hole where the wire came out?
Old 08-19-2016, 03:21 PM
cycle7447's Avatar
cycle7447
cycle7447 is offline
Received 1,696 Likes on 1,029 Posts
My suggestion - if you have it out, whey not just put a new one in and move forward.
Old 08-20-2016, 02:25 AM
From_Behind's Avatar
From_Behind
From_Behind is offline
Lots of folks (including folks at the parts counter, and probablt a lot of new techs) are under the impression that you can't replace just the bulb. The reason for that is probably because lots of touring bikes have LED lights, and they don't have serviceable bulbs. Hell, my friend and I were just talking about this . . . he got bent over for a whole new assembly, when it was just a new bulb that he needed. However, I don't see any reason why you couldn't replace the bulb. Look up part number 68000056. And, there's a section on how to replace them in the service manual. So, I'd say they're replaceable!
jsvt184
Electrical/Lighting/Alarm
04-16-2015 06:52 AM
bobg03
04-18-2013 08:49 AM
drobison
06-24-2010 08:41 AM
Stash
12-22-2007 09:15 PM
morton78
09-15-2007 04:51 AM
Quick Reply: auxiliary light bulb
