Rear Shock - 2017 Same as the Old Adjustable?
M8 Shocks
Bought the kit.
I am trying to determine if you used the new M8 shocks? I am also trying to determine if the 54000008 kit has both 54000093 & 54000094 in the box? Or is the 13” M8 shocks a bit different than the 13” shock from 54000008 that have been available prior to the release of the M8?
Both are in the kit. Same PN but the label on the shock is different; Prior had scale of Low/Med/High, new scale is numbered 5, 10, 15 and 20 with 3 additional tick marks so you know where you are adjustment wise and don't have to be riding down the highway thinking about it..LOL. Took pictures today right before test ride of a Limited. Operator's manual has new adjustment chart set up in a table where you look at the rider's weight and follow it across to appropriate additional weigh carried and you will have the appropriate clicks. Not sure if it has more capacity or just more adjustment. Either way I like it better, wish I had known before pulling the trigger but still happy.
